XJ ( X351 ) 2009 - 2019
Any of you replaced your own motor mounts?
Old May 14, 2020 | 08:11 PM
12jagmark's Avatar
Default Any of you replaced your own motor mounts?
I'm going to replace the transmission mount, and since it's a 2012, I need to replace the motor mounts too.
But the question is do I replace the motor mounts (front two) myself? Or leave that to the shop?
Does the engine need to be lifted to replace the front two mounts? Or is it not too bad of a job?
I know the transmission mount is reasonable, downright easy the way it's designed. I ordered one ($108 with shipping) from AutohausAZ two nights ago and it was at my door today, so I plan to replace that & the brake vacuum pump gasket tomorrow or this weekend.
Old May 19, 2020 | 10:05 AM
Nedoerr's Avatar
I didn’t do it myself, but I think the steering rack had to be moved to install the motor mounts.
Old May 19, 2020 | 08:16 PM
XJ8JR's Avatar
You will need to unbolt and move the steering rack and column out of the way. You will also need to lift the engine to get the mounts out. I'm not sure if there's a way around it but the manual says you have to disconnect some AC lines to make room for the driver side mount to come out.
Old May 20, 2020 | 06:48 AM
12jagmark's Avatar
That sounds like a bit of a headache. A local dealership has a coupon for 50% off labor this month, and their charge for replacing the motor mounts is 3 hours. I think I'd rather pay them $250 - $300 labor to do it than spend a whole day contorting and squeezing myself around to do that.
The way they look like they're mounted makes it look easier, like it's as simple as supporting the engine (of course), and unbolting the mounting plate-to-block, then the bottom bolt of the motor mount, then lift it out. At least the passenger side looks that easy.
BUT i'd definitely pay the Jaguar dealership $300 to do it.
I did replace the transmission mount myself the other day though. That couldn't have been easier or quicker. Nice design for maintenance.
Thanks for the input.
Old May 20, 2020 | 11:22 AM
XJ8JR's Avatar
Passenger side is MUCH easier, yes.
quartetchiang
Feb 20, 2020 04:58 AM
littlehandegan
Jan 2, 2020 08:10 PM
vdpnyc
Feb 16, 2017 11:41 AM
Badbenz94
Jun 11, 2014 10:34 AM
featherboxx
Jan 21, 2014 04:20 PM
