XJ ( X351 ) 2009 - 2019
Anyone know if this top piece on the dash...
Old Apr 6, 2022 | 10:41 AM
Krgeraci's Avatar
Question Anyone know if this top piece on the dash...
...is removable without taking out the whole dash, or removing everything underneath it to get access? Talking about the separate top piece that covers clock/air vents, need to remove mine to repair the leather cover.
Picture attached. Thanks.
Attached Thumbnails Anyone know if this top piece on the dash...-xjl-dash.jpg
Old Apr 6, 2022 | 04:17 PM
XJsss's Avatar
Looks like a lot of work
File Type: pdf
File Type: pdf
Old Apr 6, 2022 | 04:44 PM
Krgeraci's Avatar
Default Yikes!
Indeed it looks that way, think I will attempt in place, and disassembly as a second option. Thanks for the assistance!
Old Feb 27, 2024 | 02:04 AM
lotusespritse's Avatar
How did it go?
Old Feb 27, 2024 | 01:24 PM
It looks like this top piece is only held down with 4 screws in the front. The question is whether or not you can get to those 4 screws by just removing the infotainment unit, or if you have to remove the whole dash top to get to them. I can't tell from the limited pictures I have found online. The infotainment brackets may be in the way.
Old Feb 28, 2024 | 03:04 AM
Thermo's Avatar
Veteran: Navy
Krgeraci, if you are talking about the leather lifting off of the backing, people having gotten their hands on a small hyperdermic needle and put some glue inside. You can then stick the needle through the leather, get the glue on the backside and then you simply need to use some round cans or possibly 2 pieces of formed wood to push down and force the leather against the backing again. From there, you let the glue dry and you should be good to go. The needle will make very small holes that will cover themselves up once all is pressed into place.
Typhoon320i
Apr 14, 2025 08:54 PM
Fredclum
Aug 24, 2020 08:25 AM
OBC
XF (X260)
Mar 12, 2018 11:43 AM
Etip
Sep 29, 2017 04:31 PM
Adam Lueb
Apr 20, 2012 08:44 AM
