XJ ( X351 ) 2009 - 2019
Auto light delay flashing on Display Problem
Old Feb 10, 2025 | 06:17 PM
Jlohojo7's Avatar
Default Auto light delay flashing on Display Problem
So sometimes when I am driving my 2016 XJR I see in the right-hand circle on the display the message Auto Light Delay 1:00 then flash to Auto light Delay :30 then back and forth like its shorting or something. It's been doing it randomly for some time and I guess I'll finally get around to fixing it if anyone has had this issue. It will do it for a minute or so then stop and then randomly will do it again later off and on. nothing really happens other than the message and im not touching anything or doing anything other than hands on the steering wheel. SEE VIDEO ATTACHED
File Type: mov
Old Feb 11, 2025 | 10:05 AM
Vasara's Avatar
Left side stalk playing up, End of the stalk have rotate switch for these settings. (walk home lights)
I would try a drop of contact cleaner or WD40 etc thru seam wtith air pressure to get it inside for contact surfaces. Already turning it back and forth for awhile can help.
Old Feb 12, 2025 | 03:24 PM
Jlohojo7's Avatar
what is stalk ? you mean talking about the lever there ?
Old Feb 13, 2025 | 10:01 AM
Vasara's Avatar
Both sides of yor steering wheel. Left side for blinkers/lights and right side for winshield wipers.
Old Feb 13, 2025 | 10:20 AM
Jlohojo7's Avatar
maybe some lithium grease ? or graphite
Old Feb 13, 2025 | 12:52 PM
Vasara's Avatar
No, these can work more like insulators. What you need is clean contact surfaces.
Old Feb 14, 2025 | 09:46 AM
clubairth1's Avatar
Community Influencer
Yes give that a try. But my experience is it it will work for a while. I have disassembled several and re-greased them. But in the end I ended up getting a new switch to finally solve it for good.
Old Feb 14, 2025 | 06:49 PM
12jagmark's Avatar
Good advice. Rock Auto has one for a little under $260...
More Information for STANDARD MOTOR PRODUCTS CBS1892
Old Feb 15, 2025 | 11:21 AM
clubairth1's Avatar
Do you think the Standard one is as good as OEM Jaguar?
Old Feb 17, 2025 | 09:31 AM
Jlohojo7's Avatar
so thats the problem part is it? I figured the lever but didnt know exactly what. how long does the total repair take ?
Old Feb 17, 2025 | 09:55 AM
clubairth1's Avatar
Not long just be careful to avoid breaking plastic parts. You need to get the shroud off under the steering wheel so you can get to the switch.
Old Feb 17, 2025 | 04:24 PM
12jagmark's Avatar
I think so, also because it's an interior part that doesn't get much abuse. I wouldn't be surprised if they're not from the same manufacturer on things like this that are specific (but may be common t other vehicles).
The price difference between this and genuine JLR is probably several hundred dollars.
Old Feb 18, 2025 | 09:10 AM
clubairth1's Avatar
Good to know as that is a wear item and expensive from Jaguar plus how long will Jaguar keep supplying that part?
JaguarXJL15
Jun 30, 2024 02:03 PM
bakere926
Dec 8, 2023 04:48 AM
lev
Jan 28, 2020 08:55 AM
RaceDiagnostics
Oct 1, 2012 12:12 PM
brgjag
May 11, 2009 06:59 PM
