XJ ( X351 ) 2009 - 2019
Battery or alternator problems.
Old Nov 15, 2023 | 04:45 PM
Enosgl's Avatar
Default Battery or alternator problems.
Hello, all. I have a 2012 XJ s/c 5.0 that a few days ago started a snow issue. Starts and drives fine. A few days ago I got a message on my radar detector that I had low car voltage. I connected through Torgue, and it agreed with the low voltage. Again, it starts and drives fine, but shows 12.1V. I charged the battery (a 3 year old AGM) , and the voltage after charging was 14 V. Driving the car immediately afterwards the voltage continued to register 14+ volts, until I shut it down, and started it again after a few hours, when it registered 12.1V again. Looking through the posts on similar charging issues, I have seen a fusible link could cause this sort of thing. Without the complications of electronics. I normally would gravitate toward a bad alternator, but now I am not sure. Any thoughts are appreciated.
Old Nov 16, 2023 | 07:28 AM
Baltobernie's Avatar
Doesn't sound like an alternator issue, since the car managed 14V while running. All of the big-box auto parts stores will check your battery and charging system free of charge. Start from there. If that checks OK, I'd look for a parasitic draw that is occurring with the engine Off.
1996vdp
Mar 11, 2022 10:07 PM
nurquhar
Oct 6, 2018 09:36 AM
gunnerman
XJ40 ( XJ81 )
Feb 28, 2018 12:04 AM
jagtoes
Jan 29, 2016 03:44 PM
mojorising
Sep 11, 2009 08:44 PM
