XJ ( X351 ) 2009 - 2019
Best place to get "always on" power in trunk ?
Old Apr 24, 2022 | 06:03 PM
rothwell's Avatar
Default Best place to get "always on" power in trunk ?
I have a trunk project that I want to power with the key off. I want some tech outlets to charge my gadgets. I originally did this to my XK8 a few years ago.
I am still learning about the electronics in this new-fangled XJL and want to make sure I get the power from the right place.
Is there a spot in the RHS fuse panel I should use? Just go direct to the battery? What's best?
I found this where Tom did it to his XJ about a year ago. But no specifics on the connection choices.
Any guidance would be appreciated.
Old Apr 26, 2022 | 04:00 PM
leaddog11's Avatar
how about direct from battery?
Old Apr 26, 2022 | 07:17 PM
rothwell's Avatar
Yeah I am going to follow the guide Jaguar published for their battery charger outlet.
Just gotta put the right connectors on the end of my harness now.
Old Apr 27, 2022 | 06:34 AM
leaddog11's Avatar
Default guide
Could you share that guide please.
Old Apr 27, 2022 | 09:25 AM
clubairth1's Avatar
Community Influencer
See if this helps?
File Type: pdf
Old Apr 27, 2022 | 07:52 PM
tjankovs's Avatar
I used the same connection method Jaguar recommends from the aux power document. Positive fused to the battery, ground on the body post.
Tom
Old Apr 29, 2022 | 08:55 PM
rothwell's Avatar
Got the work done. Details of my DIY are here in my working thread.
Thanks again to all for the help.
RAWONE
Dec 27, 2021 08:19 PM
lazerbrains
Feb 25, 2019 04:44 PM
FastCat2011
Jun 13, 2013 03:39 PM
Frog
Aug 12, 2011 10:21 AM
