XJ ( X351 ) 2009 - 2019
Brake Pads and Wear Sensor - need advise
Old Jun 22, 2022 | 11:39 PM
S/C me's Avatar
Thanks Thermo! But now another question: If I don't pull the EPB at all (just park, block front end, jack up rear, then replace the pads, brake pad sensor, and rotors), will I have to do any recalibrating for the EPB? And should I expect to have to do anything with the ABS sensor if there aren't any codes thrown? Thanks in advance!!
Old Jun 23, 2022 | 07:58 AM
Sabrinaservicewriter's Avatar
Hi! If you are able to send me your VIN, I can give you a list of part number for the brake pads as well as the brake pad wear sensors. We have had amazing success with Akebono brake pads and have had no complaints. If you'd like just send me the VIN and I will give you the part numbers =) Hope this helps!
Old Jun 23, 2022 | 12:24 PM
S/C me's Avatar
Thanks. I have the parts, I'm just looking for clarification on the actual repair! LOL I'm a "measure twice, cut once" kinda guy when it comes to doing repairs on my cars. I like to plan for contingencies.
Old Jun 23, 2022 | 12:27 PM
S/C me's Avatar
Originally Posted by Thermo
3) before putting the wheel back on, use a screw driver or other similar rod to manually actuate the parking brake lever. pulling the arm towards the front of the car numerous times until it only goes part way (repeat for the other side).
Thermo, I've seen your advice on this technique to reset the EPB on a few different threads - so it's the way I'm going to go! Once the parts get here and I finish the job, I'll post an update!
Old Jun 26, 2022 | 09:39 AM
clubairth1's Avatar
Community Influencer
The X351 does NOT apply the EPB when the car is placed in park for some strange reason?
My S-Type and my Lincoln LS did too but not the XJ. So the EPB won't be applied until you pull up on the center console lever.
I have never had to mess with the EPB when doing my rear brakes.
Old Jun 29, 2022 | 04:50 PM
S/C me's Avatar
Thanks clubairth1. I like the sound of that even better!! LOL
Old Jun 30, 2022 | 06:06 AM
leaddog11's Avatar
When I have done the pads on my 2012, the brakes will not automatically apply themselves. So, park the car, set the parking brake, block the front wheels (front and back), then jack up the rear end. From there, you can release the parking brake and do a pad replacement like you do any other vehicle. You then have 3 options for resetting the EPB:
1) use the SDD software to tell the computer to do a EPB calibration
2) disconnect the battery to force the EPB module to lose its memory, forcing the car to do another calibration,
Great info thanks
Old Feb 17, 2024 | 08:10 PM
  #28
lotusespritse's Avatar
My 2019 applies the EPB when going into Park. And it randomly disengages the EPB when I put the car in drive. When it doesn't disengage, I can either use the parking brake lever to release it, or press on the gas a little while in gear and it will quickly release the parking brake.
I don't know if my car is normal or not, or if they changed the behavior of the EPB for later model years.
I would be very happy if it did not apply the parking brakes because I live in a flat area where we don't park on inclines. I haven't figured out how to disable it, even using some instructions I found on here. Those instructions may nor work on my model year.
Old Feb 18, 2024 | 02:28 AM
Vasara's Avatar
In beginning my y.2010 had automatic EPB, but i managed to disable it. Unfortynally its so long ago that i forget how i did it. Its either by holding/pushing EPB switch +3sek or by SDD. It stll release it once P or D selected.
Old Feb 18, 2024 | 03:16 AM
  #30
OzXFR's Avatar
None of my 2010 XFS, 2010 XFR or 2014 F-Type had/have auto EPB on, I am glad they don't, and there is nothing in any of the Owner Manuals about it so I don't think I could have turned it on even if I wanted to.
In the F-Type but not in either the XFS or XFR whacking the car in D and touching the go pedal automatically releases the (manually applied) EPB.
DGL
Dec 31, 2020 05:27 PM
trkyam
May 13, 2018 11:20 AM
michaelodonnell123
Jul 22, 2017 10:33 AM
Stuart Mackinnon
Jun 3, 2017 11:17 PM
Humphrey
Mar 23, 2016 08:29 PM
