XJ ( X351 ) 2009 - 2019
Brake torque settings
Old Apr 4, 2023 | 02:51 AM
Sphinxter's Avatar
Default Brake torque settings
Hi all.
so I have slight juddering when braking from speed, I can feel this through pedals, steering wheel and seat, I'm going to check the front discs and pads and also hub mounting surface just to see if all looks OK.
could someone give me the torque setting for the front brake set up please.
60 reg x351 3.0 d.
​​​​​​many thanks
Old Apr 4, 2023 | 04:04 PM
Thermo's Avatar
Veteran: Navy
If you can check the runout on your front rotors, per Jaguar repair manual, the runout is only allowed to be under 0.09mm. As for the torque values that you are after, For the retaining plate (between the hub and the caliper), that is supposed to be torqued to 115 Nm (85 ft-lbs). The retaining plate to caliper bolts are supposed to be torqued to 58 Nm (43 ft-lbs).
Old Apr 5, 2023 | 02:39 AM
Sphinxter's Avatar
Many thanks for that reply.
I'll have to see what I can come up with to measure the lateral runout.runout have the correct gauge but I do have digital verniers of different shapes and sizes so I'll find a method.
slugger
General Tech Help
Nov 22, 2020 12:55 PM
orangeblossom
Apr 8, 2018 04:33 AM
alfred
E type ( XK-E )
Sep 8, 2014 08:37 PM
JagTheRipper
Nov 6, 2011 03:37 AM
Cadillac
General Tech Help
Jul 9, 2011 07:25 AM
