XJ ( X351 ) 2009 - 2019
Camshaft and crankshaft sensor correlation(p0016)
Old Dec 6, 2014 | 07:42 AM
kain3488's Avatar
Default Camshaft and crankshaft sensor correlation(p0016)
I have a 2011 jaguar xjl with 24,000 miles. Starts and run ok except when idle, and I am getting 2 codes p0016 and p0366, I checked timing, chains and tensioner, replace cam sensors in bank 1 and crankshaft sensor. Codes are still there and restricted performance. What could possibly be wrong and how to fix it.
Old Dec 6, 2014 | 08:33 AM
kain3488's Avatar
Engine is a 5.0 v8 non supercharged
Old Dec 6, 2014 | 11:51 AM
XJsss's Avatar
The only help I can give you is that I too had a time when there was a slight rough idle and performance was not 100%. The dealer tech found a bad exhaust cam adjuster module. they replaced at and we are happy again. Sensors usually alert you to an issue and replacement may not remedy the actual situation. I will say that it took some time till the check engine light went on and that is how they could find the defective part. To get a check engine light there has to be a recurrence of the fault several times in a short period of an hour or two.
Old Dec 7, 2014 | 06:43 AM
kain3488's Avatar
After I erased the codes Both codes come on within 30 sec after I start the car
Old Dec 7, 2014 | 08:29 AM
kain3488's Avatar
checkout these reading, one of them jumps to 0 and two are stuck at 180 degrees and dont change at all, not sure what this means, see attachments
File Type: pdf
Old Dec 8, 2014 | 08:16 AM
XJsss's Avatar
Not knowing the exact readout results I can only surmise the cam adjuster may not be working. Bear in mind that your NA V8 has a dual profile cam so the readings may be ok but get it to a dealer and tech you have confidence in.
Old Feb 12, 2015 | 01:36 PM
mcarr's Avatar
location cam profile sensor 2010 jag xf premium
Poet
Feb 7, 2025 02:18 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
Doug S
Sep 30, 2015 02:03 AM
