XJ ( X351 ) 2009 - 2019
Can I add new coolant to old coolant
Old Oct 24, 2017 | 08:20 PM
murray2200's Avatar
Default Can I add new coolant to old coolant
I have a 2013 XJ, I bought coolant from autozone Pentofrost NF to add to my old coolant due to a low coolant message. Is it ok to mix with my old coolant?
Old Oct 24, 2017 | 09:27 PM
Thang Nguyen's Avatar
This is X400 (X-Type), some one will move you to XJ Forum, but I can answer your question: Yes you can mix new coolant with old coolant as long they are same kind.
Old Oct 25, 2017 | 02:00 AM
JagV8's Avatar
make sure they're definitely the same kind as otherwise a gel can form, blocking vital passages and then you get engine overheating.
Old Oct 25, 2017 | 02:58 AM
Welcome to the forum murray2000,
I've moved your question from X-Type to X351 forum. This is the place to post questions about your model.
The important things about coolant are specification and strength. Your XJ requires a 50% mix of water and antifreeze to specification WSS M97B44 (colored orange) Extended Life Coolant. Do you KNOW exactly what is in there now? If it was mine (with Winter coming on), I'd flush and refill.
Old Oct 28, 2017 | 03:35 AM
TheBoy's Avatar
Did you locate source of leak? Also, if the coolant is more than 2 years old, might be better to drain and refill. Never believe the hype about 5 year life. Its rubbish. From the moment it goes in, it starts to degrade, particularly its ant corrosion inhibitors.
Adam J
Oct 8, 2017 11:01 PM
Fernando
Sep 24, 2017 05:38 PM
Shoreguy
Sep 22, 2017 02:06 PM
RogB
Aug 23, 2017 04:39 PM
VancouverXJ6
Aug 21, 2017 08:32 PM
