XJ ( X351 ) 2009 - 2019
changing battery
Old May 25, 2023 | 03:36 PM
George05's Avatar
Default changing battery
AM i missing some thing ? , changing out the battery as was getting a few low battery warnings , so bought a new amg battery to replace the old 6 year one it was also an amg , disconected the old one got it out , put in new one hooked it up , nothing car wont start , i had checked the voltage before i put it in reading was 12.8 volts what am i doing wrong ?
Old May 25, 2023 | 03:52 PM
dmchao's Avatar
Does it have enough CCA? AGM battery probably doesn't matter much in terms of chemistry to start, you just need the specifications to match.
Old May 25, 2023 | 04:23 PM
George05's Avatar
Yes specs seem to match , iam at a loss unless it needs to be programmed in as its stop start
Old May 25, 2023 | 05:12 PM
George05's Avatar
All fixed , in my haste had forgoton to re conect a black lead to battery a senior moment. blush
Old May 26, 2023 | 08:10 AM
clubairth1's Avatar
Community Influencer
Hey still a good cheap fix anyway!!
Old May 26, 2023 | 11:15 AM
Stuart S's Avatar
Even though you successfully installed your new AGM battery, odds are that it's not fully charged. Many batteries sit on retailers' shelves for month's slowly discharging.
Because I don't drive enough every day, I keep both of my Jags on CTEK battery maintainers to prevent electrical gremlins.
Old May 27, 2023 | 04:02 PM
George05's Avatar
yes thanks saved about $80 bucks
Old May 27, 2023 | 04:06 PM
George05's Avatar
yes well aware but thanks had took a reading prior to install battery gave 12.8volts so all good , will be hooked up tomorrow to charger as installing new rear discs , and put car into service mode via isoft code reader to keep voltage up
Missjag
Dec 18, 2022 06:17 PM
jomo
Jun 8, 2020 06:31 PM
Jagstefano
Dec 26, 2018 04:25 AM
Cadillac
General Tech Help
Sep 23, 2014 12:39 PM
SV8Predator
Apr 12, 2009 04:26 PM
