XJ ( X351 ) 2009 - 2019
considering a 2013 XJ Portfolio with knock sensor issue
Old May 29, 2025 | 11:59 PM
mhannaoui's Avatar
Default considering a 2013 XJ Portfolio with knock sensor issue
Hi,
I'm considering buying a 2013 Jaguar XJ Portfolio with 101,000 miles. The car currently has a check engine light on and is in "restricted performance" mode due to a faulty knock sensor. The current owner had it inspected by a mechanic, who quoted $1,900 for the repair. If I go through with the purchase, I plan to do the work myself.
While I'm not new to Jaguars—having owned an X308 and an X350 (which I had for eight years until just recently)—this would be my first experience with the X351.
I inspected the car today and pulled the diagnostic codes. In addition to the knock sensor issue, there are several other codes that may indicate further problems. Cosmetically, the vehicle is in good condition, though it needs a replacement center console faceplate and a new start/stop ignition button. Everything else looks solid.
The engine doesn't start immediately—it takes about 3–4 seconds of cranking. I was told this behavior began after the knock sensor issue. Once running, it sounds fine,
Below is the list of codes I retrieved. What are your thoughts? Do you see signs of more serious underlying problems?
P007B - Charge air cooler temperature sensor circuit range/performance - Bank 1 (repeated twice)
P0111 - Intake air temperature sensor 1 - circuit range/performance
P0442 - Evaporative emission system leak detected (small leak)
P0335 - Crankshaft position sensor A circuit
P2066 - Fuel level sensor B - circuit range/performance
P026A - Charge air cooler efficiency - Below threshold
U0447 - Invalid data received from gateway A
P0234 - Knock control system error
P0456 - Evaporative emission system leak detected (very small leak)
Thanks,
-mo
Old May 30, 2025 | 12:33 AM
NBCat's Avatar
Some of the DTCs may be caused by a failing or weak battery.
Old May 30, 2025 | 05:12 AM
Jaaag_drivah's Avatar
Charge air cooler codes are indicative of a failed intercooler pump, a common problem. A Bosch 010 or ZZP intercooler pump is nearly a direct bolt in replacement with a bit of wiring harness work.
Keep in mind to replace the knock sensors you need to remove the supercharger. While you're there you might as well replace the valve cover gaskets and the plastic cooling system components as these will fail eventually also. You're looking at over $1200 in parts to do all of this already.
Old May 30, 2025 | 08:37 AM
clubairth1's Avatar
Community Influencer
That car is worth very little. Not sure I would even offer $5K.
Old May 30, 2025 | 10:58 AM
mhannaoui's Avatar
Thanks for the feedback. Will keep them in mind while contemplating and making my decision.
Mikelikesfilms
Apr 24, 2025 05:20 PM
AVRO XJS
May 30, 2024 04:26 AM
JaguarXE20
Diesel variants - All models
May 8, 2024 01:32 PM
rowlands
Dec 18, 2023 02:27 PM
kenncl
Jan 17, 2014 10:53 AM
