XJ ( X351 ) 2009 - 2019
:(.Coolant leak.
Old May 1, 2020 | 06:29 PM
Nedoerr's Avatar
I can verify that the supercharger coupler will do that to the s/c snout without the stop-start system. Snout & coupler replacement is best.
Old May 1, 2020 | 06:53 PM
ricardoa1's Avatar
I got the green solid coupler on already. Bearings appear good and the green coupler doesn’t even touch the damaged area. It grabs at the fingers of the hubs. SC turns ok a little resistance from the tight tolerances on the lobes. I’m used to non TVS Eatons resistance witch turns very freely. The TVS feels like it has more resistance. Similar to my Whipple and the Kenne Bell which are twin screws and are very tight and hard to turn by hand, this is on my other cars.
Old May 1, 2020 | 06:57 PM
Nedoerr's Avatar
Sounds good. Yes, the spring coupler is probably the biggest issue (spring wears into the metal). I presume you purchased the green oil-filled coupler, which is reported to be much better. Glad you got it taken care of.
All the best.
Old May 1, 2020 | 07:58 PM
ricardoa1's Avatar
All the best.
Yup, But If it’s filed I would not have known it. It’s hard Delrin like plastic. IDK. Fluid flush also pending. The GM vendor shipped but FedEx is doing loops with it in the truck.
Old May 2, 2020 | 09:36 AM
clubairth1's Avatar
Community Influencer
Great pictures!
Really shows the improved smooth seams on the plastic parts.
I don't understand how the coupler can be oil filled nylon?
Never heard of that description before.
Old May 2, 2020 | 10:44 AM
Vasara's Avatar
Material are called that.
More here: https://www.alro.com/divplastics/Pla...ct_Nyloil.aspx
Old May 2, 2020 | 12:15 PM
ricardoa1's Avatar
Haha makes sense thanks for the clarification.
Old May 3, 2020 | 02:51 PM
  #28
clubairth1's Avatar
Yes thanks for that.
It's name pretty much means what it says.
Fernando
Sep 24, 2017 05:38 PM
Ken2839
Oct 3, 2016 09:42 PM
stephen11962
Dec 6, 2010 07:38 AM
sempire
Nov 18, 2010 09:20 AM
