XJ ( X351 ) 2009 - 2019
Coolant temperature sensor 2 code?
Old May 14, 2021 | 09:03 AM
1995XJSGuy's Avatar
Default Coolant temperature sensor 2 code?
I just picked up a 2012 xjl portfolio (5.0 N/A), and I absolutely love it. But, I got in it this morning to go to work, and I have a check engine light. I pulled the code and it says “coolant temperature sensor 2 fault” as a permanent code, any help would be nice, like where to find one, or how to replace it. Also, the dealer I bought the car from did the timing chains, guides, and tensioners, and this code showed up 2 days after I finally took delivery, so it’s the first time it’s really been driven since they did that work, any chance it’s related so they can replace it for me? Thank you!
Old May 14, 2021 | 09:30 AM
Enosgl's Avatar
I had an indy Jag specialist do the front end of my 2012 5.0 s/c motor in October, and had the same thing happen. A few days after picking up the car, it threw P0128 and P2183 codes (Engine coolant temperature sensor 2). I also noticed that the live temp (on my scanner) was a bit cooler than it was in the past (180 vs 192) . I asked the mechanic (I didn't want to take it back since he is 1:15 away) and suggested the thermostat was sticking open. Maybe some debris entered the cooling system when it was opened? Replaced the thermostat/housing unit with a new OEM (about an hour and less than $100.00) and it has not come back since.
Old May 14, 2021 | 09:57 AM
1995XJSGuy's Avatar
First, thank you for the quick response! im at work and this is stressing me out a little bit since its the weekend and wanted to take it out with all my friends for the first time since i took delivery. On the topic of codes, i only have 1 code, P2183, with the description "Engine Coolant Temperature Sensor 2 Circut Range/ Performance", not the P0128. Do you think it could still be the thermostat without that code?
Old May 14, 2021 | 11:41 AM
Enosgl's Avatar
The P0128 was a "Coolant below temperature". Not sure where you are located, but I am north of Chicago, and it was December, so coolant below temperature was no surprise. No guarantee, but that was what Mike at Eurotoys suggested, and it I have not seen the codes come back yet after replacing it.
tony bosco
Nov 1, 2016 06:22 AM
mick99
Feb 1, 2016 10:51 AM
RSsteveH
Jul 5, 2014 03:40 AM
Kennedy
May 11, 2010 10:20 AM
