XJ ( X351 ) 2009 - 2019
Coolant temperature sensor
Old Mar 18, 2023 | 12:05 AM
reallyneedhelp's Avatar
Default Coolant temperature sensor
If anyone knows where the engine coolant temperature sensor is located I would really appreciate it if you helped me out
Old Mar 18, 2023 | 07:38 AM
Thermo's Avatar
Veteran: Navy
reallyneedhelp, you do not specify what engine you have. So, I am going to take a stab at what you are after and this should hopefully get you on the right path. If you have the 5.0L petrol/gas engine, then I recommend you remove the cover off the top of the engine. Next, locate the throttlebody and find the coolant hose feeding the throttle body. Now, follow this back about 12 inches or so to a plastic coolant manifold.on the right hand side of the engine. Where the hose enters this manifold will be a bulge, the lower half of that bulge has the coolant temp sensor in it.
If you have the 3L diesel engine (only available outside of the US), then you need to look in the left hand front corner of the engine bay in the EGR cooler inlet pipe. You should see the sensor sticking up there.
Old Mar 19, 2023 | 07:50 AM
clubairth1's Avatar
Community Influencer
Yes car details are needed to answer that.
Old Mar 19, 2023 | 08:16 PM
IanXF's Avatar
the sensor is mounted on the rear plastic crossover pipe back of the engine
at the bottom right
on a 5.0 and 3.0 petrol engine I hope that helps.
Old Mar 25, 2023 | 09:43 AM
apllrd's Avatar
It's a bit of a pain to get too. Much easier if you remove the intake manifold first. Mine was throwing a fault but changing it didn't clear after I swapped it though.
Old Jun 7, 2026 | 04:07 PM
danu99's Avatar
Default Help. Info needed
Hey guys.
can someone help me with the precise location for the coolant temperature sensor ?
just need to take the connector off to see if the radiator fan starts.
because it’s summer and I don’t hear full blast radiator fan…… at all. Temp is constant at 90.
just suspicious that the fan it’s not working at top speed, only with clima on at about 20-30%. Speed.
so…. Taking the connector off the sensor should start the fan at full speed?
btw…. From diagnose program not original jlr…. The fan doesn’t respond to changes in rpm
so…. Location for temp sensor pleaseeeeeee
Old Jun 8, 2026 | 11:16 AM
clubairth1's Avatar
What engine do you have?
Old Jun 8, 2026 | 11:56 AM
danu99's Avatar
diesel 3 l 275hp
Old Jun 8, 2026 | 12:02 PM
clubairth1's Avatar
Thanks. I thought you did. I only have experience with the V-8 engine.
Old Jun 8, 2026 | 12:39 PM
danu99's Avatar
So…. Guys…. Need some info please
coolant temperature sensor location please? Could someone pin point exactly?
thanks in advance
Old Jun 8, 2026 | 02:45 PM
RoverJoe's Avatar
We do not get very many diesels over here, so I'm not sure how helpful I can be with it, but I will try. You can verify the fan runs by unplugging the sensor, you could also disconnect the PWM wiring at the fan itself which will force it to 100%.
If the car is not overheating and the a/c is cooling well, you may not need the fan to go faster. It's quite variable, and if the airflow at 30% is good, it will stay there. No reason to run it faster for no gain.
Old Jun 9, 2026 | 03:41 AM
danu99's Avatar
hey…. Thanks you.
great stuff. Found it. Disconnected. Not a peep from the radiator fan. So…… 🤣 I now know for sure
jsjunky
Jul 10, 2024 12:26 AM
Jagguyx300
Jan 15, 2021 05:59 PM
pnhb93
Nov 16, 2017 05:29 PM
phaelax
Nov 30, 2012 02:01 AM
georgia boy
Jan 26, 2011 08:47 AM
