XJ ( X351 ) 2009 - 2019
Coolant temperature sensor
Old Mar 18, 2023 | 12:05 AM
reallyneedhelp's Avatar
Default Coolant temperature sensor
If anyone knows where the engine coolant temperature sensor is located I would really appreciate it if you helped me out
Old Mar 18, 2023 | 07:38 AM
Thermo's Avatar
Veteran: Navy
reallyneedhelp, you do not specify what engine you have. So, I am going to take a stab at what you are after and this should hopefully get you on the right path. If you have the 5.0L petrol/gas engine, then I recommend you remove the cover off the top of the engine. Next, locate the throttlebody and find the coolant hose feeding the throttle body. Now, follow this back about 12 inches or so to a plastic coolant manifold.on the right hand side of the engine. Where the hose enters this manifold will be a bulge, the lower half of that bulge has the coolant temp sensor in it.
If you have the 3L diesel engine (only available outside of the US), then you need to look in the left hand front corner of the engine bay in the EGR cooler inlet pipe. You should see the sensor sticking up there.
Old Mar 19, 2023 | 07:50 AM
clubairth1's Avatar
Community Influencer
Yes car details are needed to answer that.
Old Mar 19, 2023 | 08:16 PM
IanXF's Avatar
the sensor is mounted on the rear plastic crossover pipe back of the engine
at the bottom right
on a 5.0 and 3.0 petrol engine I hope that helps.
Old Mar 25, 2023 | 09:43 AM
apllrd's Avatar
It's a bit of a pain to get too. Much easier if you remove the intake manifold first. Mine was throwing a fault but changing it didn't clear after I swapped it though.
jsjunky
Jul 10, 2024 12:26 AM
Jagguyx300
Jan 15, 2021 05:59 PM
pnhb93
Nov 16, 2017 05:29 PM
phaelax
Nov 30, 2012 02:01 AM
georgia boy
Jan 26, 2011 08:47 AM
