XJ ( X351 ) 2009 - 2019
door wont open
Old Oct 22, 2024 | 09:56 PM
dazak's Avatar
Default door wont open
Hi All
Rear door wont open from either outside or inside what can i do to get the door open to investigate the fault or does any one heve experiance of this problem.
the door is unlocked according to the door symbol
thanks in advance
Old Oct 24, 2024 | 01:44 PM
fossberry's Avatar
That's a tough one. Should be able to get the door card off from the inside but to make this easier I'd suggest removing the rear seat first. Not a bad job but made trickier as you'll need to be quite flexible to release the seat from the non opening side and applicable wire harnesses underneath. Move and tilt the front seats as far forward as possible to give you more room to do this. Once out this should enable better access to pry off the door card and see what's going on. Good luck!
Old Oct 24, 2024 | 10:04 PM
dazak's Avatar
thanks for the input fossberry
sounds like a job beyond my level think this will end up being one for the main dealer
Old Oct 25, 2024 | 07:29 AM
clubairth1's Avatar
Community Influencer
If you can post back how they fixed it?
dadspet
E type ( XK-E )
Aug 1, 2024 03:49 PM
tberry6686
Jan 28, 2023 09:40 AM
mad dog
Jan 28, 2023 04:30 AM
asjdhsajhdfj
Dec 26, 2022 04:22 PM
