XJ ( X351 ) 2009 - 2019
Engine shudder when turning off
Old Mar 8, 2024 | 11:01 AM
JaguarXJL15's Avatar
Default Engine shudder when turning off
My engine shudders, shakes or moves whatever you want to call it for 1 second every time I turn off the car
What is causing this bad motor mounts? or could it be something else?
Old Mar 8, 2024 | 12:45 PM
NBCat's Avatar
Inspect the transmission mount for wear.
In some cases, the supercharger snout torsion coupling can create vibrations as the engine is turned off.
Old Mar 8, 2024 | 05:11 PM
I don't have a transmission mount I have a transfer case mount it was inspected and looked brand new
Old Mar 9, 2024 | 11:27 PM
QP7's Avatar
QP7
It is the loose supercharger snout torsion coupling on mine. If so, you should get that repaired before it gets worse, and then you have to rebuild the supercharger...
This may not be the right one for your car, but call these guys are great - first rate out in CA.
https://superchargersonline.com/prod...e-service-kit/
https://superchargersonline.com/product/eaton-spring-torsional-coupler-for-jaguar-land-rover-range-rover-5-0l/
https://superchargersonline.com/product/jaguar-supercharger-rebuild/
Actually, I realize I may have screwed up as I think I bought the 5.0 litre one by mistake, and this is slightly different from the 3.0 litre one. My bad...
Old Mar 22, 2024 | 11:28 AM
yeah that is the problem with mine I get a loud clonk on shut down and a couple other noises well after the engine is off also the engine shakes can be felt inside the car watch video
jayd2
Jun 25, 2025 09:07 PM
benji808
Nov 6, 2023 08:44 PM
vdpnyc
Feb 16, 2017 11:41 AM
Johnken
Jan 19, 2016 09:48 AM
marvin.d.miller
Nov 16, 2014 04:35 PM
