Engine pulls to right when revving engine
Old Oct 29, 2023 | 12:51 PM
benji808's Avatar
Default Engine pulls to right when revving engine
See attached video. Most likely motor mounts? Or is there something else on these cars? No noise or banging at this point.
File Type: mov
Old Oct 29, 2023 | 01:09 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
I couldn't play your .MOV file, but the rotational movement of an engine running counter clock-wise (viewed from drivers seat) would be to the right (viewed from drivers seat). But this movement should be minor, I'll go out on a limb and say about 1/2", much more than that and your motor mounts may have separated. Have someone rev the engine while you watch the mounts and see what's happening.
Dave
Old Oct 29, 2023 | 01:10 PM
Doug's Avatar
I don't see anything worrisome.
Old Oct 29, 2023 | 01:30 PM
LT1 jaguar's Avatar
OK, able to play .MOV video. I would certainly defer to Doug, the rubber in Jaguar mounts could very well be slightly softer than other mounts and allow the engine to move a little more. It appears to move slightly more than the engines in my U.S. vehicles and will would move even more when under a load.
Old Oct 29, 2023 | 06:47 PM
Fraser Mitchell's Avatar
As Doug Dwyer says, t he movement of the engine looks perfectly normal to me !
Old Nov 4, 2023 | 11:45 AM
pfl's Avatar
pfl
To mee it would be fine if the gear is engaged and strain on the drivetrain. If the mov had been made with the garbox in neutral I would consider changing the mounts
Old Nov 6, 2023 | 08:44 PM
slofut's Avatar
Watch the movement in fwd and reverse with brakes applied to check motor and trans mounts. I've seen v8's raise up and sit back down with a clunk! Also seen them dimple a hood in bad cases.
Lycaon
Feb 27, 2023 12:11 PM
vdpnyc
Feb 16, 2017 11:41 AM
hen555
Aug 3, 2015 05:49 PM
vincent661983
Sep 29, 2014 05:46 AM
driver safz
Oct 3, 2011 04:37 PM
