XJ ( X351 ) 2009 - 2019
Engine wiring diagram
Old Nov 27, 2024 | 05:29 AM
albdiag's Avatar
Default Engine wiring diagram
Dear friends.
I am looking for engine wiring diagram for the following vehicle:
Jaguar XJL, Year 2011, Engine 3.0L petrol (V6)
VIN: SAJAA20D8BFV20996
I did find on google wiring for V8 (8 cyl) but not for V6
I see manuals on this forum but i cant download them. Probable because i am new member and do not have download privileges yet.
I am interested espacially in the wiring diagram of the fuel pump in tank
Thank you
Lomi
Old Nov 27, 2024 | 05:54 AM
albdiag's Avatar
I am struggling to understand if this model have a fuel pump controller or not and if yes were is it located?
Old Nov 27, 2024 | 07:04 AM
clubairth1's Avatar
Community Influencer
Probably better to start from the beginning?
What's wrong with your car?
What have you done so far?
What changed after you did that?
Old Nov 27, 2024 | 07:09 AM
albdiag's Avatar
Thx for the reply
car is imported from abroad as non starter. I see that in the fuel pump there is no GND PWM signal. (possitive from relay is ok) I would like to see the wring diagram for this car as we do not find and fuel pump controller.
(in the 5.0L versions on wiring diagram i see fuel pump controller)
Wiring would help a lot
Looks like this model is with same engine as older 2006-2009 XF (x350) with a xjl body.
I can find the fuel pump controller
Thx again
Old Nov 28, 2024 | 07:24 AM
clubairth1's Avatar
Ok good. So you have power but not ground at the fuel pump? Can you run a temporary ground to troubleshoot?
The starter does turn the engine over right? But the engine does not start or sputter any? So no fuel.
But as always I see no codes or that you checked for codes? Can you do that? What scanner do you have?
Old Dec 4, 2024 | 06:55 AM
albdiag's Avatar
Originally Posted by albdiag
Dear friends.
Thank you
Lomi
I need the location of fuel pump controller for this VIN car. Please
Thx
Arvis
Oct 3, 2023 10:05 AM
panthera999
Feb 14, 2023 10:06 AM
PhilipM
XK120 XK140 XK150
Aug 14, 2015 06:40 AM
Adam Lueb
Oct 29, 2010 10:04 PM
