XJ ( X351 ) 2009 - 2019
X351 no Phone connect view, DAB radio, Navigation, TV
Old Jan 12, 2018 | 04:02 AM
TomPraz89's Avatar
Default X351 no Phone connect view, DAB radio, Navigation, TV
Hi few days ago when I finished shopping I realised that the radio doesn't react, after a wile I realised that sat nav doesn't react either and also can't connect my phone by bluetooth. Does any one of you have already had such an issue or even better know what can be wrong ?
I ve just spotted that it might be fuse as there is one which is responsible for all those issues the thing is I can't find the box. Can anybody send me a pic of this box?
I was following by the photo on this webpage( https://topix.jaguar.jlrext.com/topi...05b7012/en_GB? ) but still can't find it and check whether its a fuse or not ?
many thanks
Old Jan 12, 2018 | 06:46 AM
dewillia's Avatar
Fuse box is behind the centre armrest in the back, pull armrest down then the leather cover
Old Jan 14, 2018 | 06:46 AM
TomPraz89's Avatar
Thx solved ;D
Old Jan 14, 2018 | 07:00 AM
dewillia's Avatar
Sweet
Old Dec 3, 2021 | 09:12 AM
J11HTY's Avatar
Default Same issues
Originally Posted by TomPraz89
Thx solved ;D
Hi there
please can you tell me exactly which fuse was responsible for the issue as I have the same problem
regards John
Old Dec 3, 2021 | 09:19 AM
XJsss's Avatar
What year is the XJ and how old is the battery. These Jags are notorious for going wonky when the battery is old and cannot supply the proper amperage. BTW AGM batteries from many manufacturers are best for these beasts.
Old Dec 3, 2021 | 10:44 AM
J11HTY's Avatar
Hi there
thanks so much for your response
Its a 2013 3.0 diesel and I have just replaced the big battery 2 days ago and it hasn’t cleared the issue. I changed the s/s battery about a year ago too
My mechanic has put it on his diagnostics earlier and no faults were showing
He was unaware at the time of the third fuse box in the armrest where I believe a fuse governing these aspects may be
Hope that helps
regards John
Old Jun 20, 2024 | 02:38 PM
Matty21's Avatar
Default Anyone know the fix
Hi all,
I am new here but have seen this thread and have the same issue.
Does anyone know how this was resolved?
Thanks.
Matty
Old Jun 20, 2024 | 03:00 PM
J11HTY's Avatar
Default Resolved
Originally Posted by Matty21
Hi all,
Thanks.
Matty
Hi Matty
The circuit which governs this is protected by a 40A fuse which I believe was located behind the centre rear armrest, just open the leather panel
For me when the fuse was replaced it blew straight away and was eventually diagnosed by Jagtech Stockton as being a defective ecu unit located in the boot behind the RNS trim , mounted to the inner side of the wing . A new module was £1000+ from Jaguar plus fitting, However, Jagtech located a used module from a compatible XF and once replaced it worked perfectly fine at a total cost of £400 fitted with warranty
Hopefully yours will just be a blown fuse and will work when replaced
I believe that I should’ve changed both batteries at the time the stop start battery was replaced as I believe that the voltage drop of the old main battery caused too much pull of amps which popped the ecu and the fuse
Hope this helps, Regards John
Old Jun 21, 2024 | 01:27 PM
Matty21's Avatar
Hi John,
Thanks for all the info.
I have looked behind the armrest and there are no 40amp fuses there. Is there any chance you could find out which fuse you mean?
I know this is a long shot, but it’s really desperate measures stage for me.
Thanks.
Matthew
Old Jun 21, 2024 | 03:29 PM
J11HTY's Avatar
Default Fuse
Hi Matthew
Leave it with me and I will message the technician who did the job and ask him
Regards John
Old Jun 21, 2024 | 03:40 PM
J11HTY's Avatar
Message sent , waiting for response 👍
Old Jun 21, 2024 | 03:47 PM
Matty21's Avatar
This is above and beyond John. I really appreciate the effort.
Thanks.
Matthew
Old Jun 21, 2024 | 03:49 PM
J11HTY's Avatar
Just replied this ….
Hello mate how’s things it’s in the rear junction box mate if a remember correctly on the right hand side in the boot
hope that helps John
Old Jun 21, 2024 | 03:50 PM
J11HTY's Avatar
Let me know how you get on 👍
Old Jun 21, 2024 | 04:30 PM
J11HTY's Avatar
Apparently it’s a small fuse box he believes
Old Dec 4, 2024 | 09:07 AM
Matty21's Avatar
Sorry for the really late reply but there have been a few issues in life I have had to deal with.
Anyway, Mistermatic my local Jag specialist can’t work out the issue so it has gone into Jaguar.
So far today they have said that the ACM has a fault and that a software update could brick the whole audio system They recommend I buy a new ACM at £2660+vat!! Not including installation!
They said that the fuel filter I had put on by the Jag specialist was an inferior part and it should be replaced. I asked the specialist and he has said it is a Delphi part that comes from an authorised Jaguar supplier.
They said that it needs a new DPF.
They have said there is a fuel pressure problem and water in the fuel. I knew there was water and have asked them to drain the tank. They said they would test the fuel quality. I asked why? We both know there is water in it. What will testing it change?
At this point I am looking well over £5k to get it sorted.
Any thoughts?
Thanks.
Matthew
xdave
Jun 28, 2022 01:40 PM
Cambo
Apr 18, 2022 02:15 PM
Cambo
72
Feb 17, 2022 07:17 AM
XFpostwarrentyissues
Sep 21, 2017 12:44 PM
rogerdodger
Sep 4, 2012 07:14 PM
