XJ ( X351 ) 2009 - 2019
A few things.
Old Nov 9, 2023 | 11:48 AM
fredom dsm's Avatar
Default Symposer
Quick question about the symposer, mine has an electrical connection, if I delete it and do not plug that back in, would it throw a code? What do I do? Please see pics.
Old Nov 9, 2023 | 02:30 PM
lotusespritse's Avatar
Good question. When I has the RRS apart recently, I couldn't find that answer, so I just left everything in place and made a blanking plate out of aluminum sheet to block off the hole in the supercharger. I just sandwiched that plate between the hose and the supercharger with silicone to provide a good seal on the side of the supercharger. In my case, that hose to the supercharger had a crack and became a vacuum leak that was causing misfires and lean codes on that side of the engine. I am glad to have it disabled. I will do the same with my XJL soon.
Old Nov 9, 2023 | 02:38 PM
clubairth1's Avatar
Community Influencer
If you remove the entire assembly you will need a block off plate to cover the hole. There is an expensive LR part or you can make your own plate as it's just a flat plate.
Plus you need to block off the vacuum hose. So different degree's of removal!
Here is my thread on removing the symposer on my 2014 XJR
2014 XJR Symposer Removal
With the severe lack of room at the back of the engine I went with a simple plugging operation. When I remove the SC in the future I might take more of it out.
I have no errors with how I did it.
That's a lot of work to remove all of it too!
carzaddict
Photography
Nov 26, 2023 11:04 AM
JeffR1
Photography
Feb 17, 2022 06:53 PM
Kriss Vector
Jun 5, 2019 02:51 AM
AJB2
Apr 17, 2019 11:35 PM
Wes_R
Detailing / Car care
Sep 6, 2013 05:54 PM
