XJ ( X351 ) 2009 - 2019
Front Hub Replacement
Old Aug 1, 2020 | 04:35 AM
OGR4M's Avatar
Default Front Hub Replacement
My XJ is warping discs, after multiple sets I can only assume that the hub flange/face is no longer true on one or both sides
the faces are fairly well corroded, where the disc seats, which may be the problem.
the hub/bearing assembly seems like a simple DIY job to fix, but I’m not sure whether to trust the eBay specials that I’ve found
is there a part number available (I can’t find any on my ruined assemblies...) or are the eBay models actually ok? I’m really loathed to pay main dealer prices, so Britcar is the next port of call, but need a part number to get through their slightly unfathomable website...
any info is greatly appreciated, wobbly brakes are getting annoying!
Old Aug 1, 2020 | 05:45 AM
Fraser Mitchell's Avatar
Have you thought about the calipers ? A sticking piston or slide can cause the problem. The only real way to see whether it is the hub is to mount the new discs on and then use a dial gauge to test for runout.
Old Aug 1, 2020 | 06:02 AM
OGR4M's Avatar
Callipers were my first thought - when I started having problems I went to my trusted garage and they used some gubbins to test the drag of the wheel, to see if the brakes were releasing slowly - but they’re absolutely spot on, no dragging at all
which is annoying, as I feel that would have been an easier (cheaper) fix
laguillotine
Mar 7, 2020 09:45 AM
bigcash
Sep 17, 2017 09:22 PM
cat_fancier
Apr 26, 2017 07:33 AM
elvinjones
Feb 27, 2015 10:26 AM
randyb
Jul 15, 2013 04:19 PM
