XJ ( X351 ) 2009 - 2019
Front left brake line
Old May 31, 2022 | 04:10 PM
jagdaddy90210's Avatar
Default Front left brake line
Anyone know of a metal brake line that will fit the jaguar XJL That isn’t oem. I’m just trying to not spend $200 on a metal line if I don’t have to. I’ve called every part store in my area and they don’t even have a part number.
any help would be very much appreciated as I’ve already purchased a new caliper and pads and everything else and it’s getting rather expensive.
Old May 31, 2022 | 04:30 PM
Thermo's Avatar
Veteran: Navy
jagdaddy, your best bet would be to find a local performance shop. You can then pull your brake line and take it in to them and they can match up the ends and make the line out of just about anything you would want. still going to be a pretty penny, but should be about half of what OEM is.
Old Jun 1, 2022 | 10:43 AM
atraudes's Avatar
You can bend and flare your own too, if you're so inclined.
https://knowhow.napaonline.com/tips-...nd-fuel-lines/
Old Jun 1, 2022 | 05:21 PM
Fraser Mitchell's Avatar
Also you can get the pipe made from Kunifer metal pipe. This is a cupro-nickel alloy, the name tells you what is in it. The iron content is quite low.
Mongoose
25
Aug 16, 2021 12:04 AM
yachtmanbuttson
Jun 7, 2020 12:29 PM
yachtmanbuttson
Aug 25, 2019 08:48 AM
DJ-Roy
Oct 25, 2013 04:37 PM
TN8Shooter
Jun 11, 2011 09:51 AM
