XJ ( X351 ) 2009 - 2019
Front and Rear Climate Control Panels INOP
Old Jul 25, 2022 | 02:14 PM
Jplants01's Avatar
Default Front and Rear Climate Control Panels INOP
Good afternoon Jag Team,
I have been reading a few posts in here and have yet to come to a definitive solution. The Front and Rear Climate control Panels are INOP and I can not figure out which fuse or relay is associated with those control panels. Panels were working intermittently and now have ceased to function at all. I have disconnected the battery in the trunk (and then closed the trunk so I found out how to open the trunk with a disconnected battery) and let the system clear out for an hour or so and reseated the connection cables but to no avail. I want to check the relays/fuses before I have to take the center console apart. Any help would be greatly appreciated!
These are the 2 fuses in the passenger compartment fuse box that I think are related to the control panels but replacing them has not changed the outcome.
F28 20A Yellow Rear seat dual climate control module.
F29 20A Yellow Front seat dual climate control module
2012 XJ 5.0
Old Jul 27, 2022 | 05:43 PM
clubairth1's Avatar
Community Influencer
Do you have the ability to get the car hooked up to the SDD?
You may have deeper problems than just no power since both panels are doing the same thing.
Sandro Felisio
May 12, 2026 09:14 AM
Kasino
Apr 2, 2022 01:06 AM
Tahoe Dave
Feb 24, 2013 10:05 PM
quaker13
Aug 25, 2011 02:03 PM
