XJ ( X351 ) 2009 - 2019
Fusebox location
Old Apr 16, 2015 | 05:39 PM
moar's Avatar
Default Fusebox location
Was removing the rear parcel shelf ready for tinting and saw the location of one of the fuse boxes for the car....
Heres hoping you don't get a blown fuse!
Old Apr 17, 2015 | 03:13 AM
moar's Avatar
Ignore, you access via the arm rest!
Old Apr 17, 2015 | 03:45 AM
I'd have been giving the whole tinting idea second thoughts before getting that far.
Old Apr 17, 2015 | 04:03 AM
moar's Avatar
Looks way worse than it is.
Remove bottom seat - easy has quick release and couple of connections
Remove back seat - 4 nuts along the bottom and pull the string. Seat moves forward, unplug electrical connections and carry out of car.
Remove C pillar trim, just pulls out.
Remove Rear quater trim, 1 torx bolt and pulls out.
Remove parcel shelf - loosen 1 8mm bolt on each side. Undo 3 quick release plastic screws along the front and pull up and out.
30 mins work.
jimforrest (uk)
Feb 28, 2019 06:42 PM
jorgef858
Jan 14, 2016 11:32 AM
damienedwards
Nov 22, 2015 10:51 AM
zoozth
Sep 29, 2015 07:28 AM
