XJ ( X351 ) 2009 - 2019
Grill camera acc
Old Jan 18, 2021 | 04:26 PM
etheliters's Avatar
Default Grill camera acc
Im updating my front end to 2017 from 2014. What is the rectangular hole in the front grill specifically for? What is the part called? I think its a camera but I can't find the part that will bolt in to fill the hole.
Old Jan 18, 2021 | 06:16 PM
xdave's Avatar
The big rectangular hole you can put your hand through then that is the cover/badge that fits in front of the ACC sensor on the 2016+ models. They use a flat plastic cover rather than the contoured badge. C2D35915 goes with the chrome grille, and C2D35916 with the black grille. There are no bolts - it just clips into place. You can get the main grille without the ACC sensor that takes a normal round/contoured badge if you would prefer that look. (It might be cheaper to get a new grille than to get the insert.)
The smaller hole right at the very top is for the camera.
Old Jan 19, 2021 | 08:10 AM
etheliters's Avatar
Ty. You're a brain beast!
UltraPeepi
Dec 28, 2019 11:18 AM
Wickster
XE ( X760 )
May 24, 2019 11:21 AM
triplekg
Nov 12, 2016 11:19 AM
orangeblossom
Apr 28, 2016 05:47 PM
j_bond
Mar 30, 2011 11:57 AM
