XJ ( X351 ) 2009 - 2019
Heated/cooled seat module location
Old Sep 20, 2023 | 11:10 AM
Timothy Geyer's Avatar
Originally Posted by Sphinxter
Hi mate.
yes thats me i am Vic Tor 😆.
I did say on this thread that there is one under the passenger carpet.
Did it sort you're issue?
What a small world!
I swapped it, but it didn't fix the problem. Drivers seat doesn't heat or cool down. I can hear that the seat cooling fan doesn't come on. What do you glean from that? If it was the heating element in the seat methinks that the cooling would still work?
All fuses are ok. Your thoughts?
Regards,
Tim
Old Sep 20, 2023 | 11:40 AM
Vasara's Avatar
Weakest part of the system are the fan, then comes the peltier element making the cool/heat. One on each bench / rest.
Old Sep 20, 2023 | 01:54 PM
Taking the car to dealership on Friday. Interested to hear their analysis.
Old Sep 20, 2023 | 02:01 PM
Sphinxter's Avatar
Be sure to let me know mate. I have similar issue still, mine cools and massages but won't heat, fan starts but stops after 30 seconds.
Old Nov 1, 2023 | 12:57 PM
Alamu's Avatar
Default Heated seat fan cutting out after 30 seconds
hi mate did you manage to work out what was causing this issue as my 2012 xf is doing the same thing,
Old Nov 2, 2023 | 10:58 AM
clubairth1's Avatar
Community Influencer
Have you checked to see if the cover/filter to the fan is full of junk?
Jaguar/Ford have gone back and forth on this and the early cars have a seat filter but in later years they removed any filter media and just made it an open cover.
A good thread with pictures but this may NOT be your problem. So just something to check.
X351 Seat Filters
Old Nov 2, 2023 | 12:55 PM
lotusespritse's Avatar
X351 Seat Filters
My 2019 XJL has the same filter media as my previous 2011 XF Premium's.
Old Nov 2, 2023 | 02:27 PM
  #28
Alamu's Avatar
[QUOTE=clubairth1;2692210]Have you checked to see if the cover/filter to the fan is full of junk?
X351 Seat Filters
The filters on both front seats seem quite clean, found a split in the duct on the fan/motor/ Pelletier that’s fitted in the back of the seat, waiting for the new part tomorrow and hopefully that resolves the issue
Old Jun 18, 2024 | 01:49 PM
Hi mate.
Hi Vic Tor. I finally found the fault. The peltier element was corroded and not working/or the fan wasn't working. Replaced it with a new fan and new peltier element and seat heating working now.
Computer Budda
Jan 19, 2021 01:37 PM
Turtlepower
Dec 10, 2019 10:37 AM
Jagboi64
Jan 10, 2016 08:43 AM
riverrob
Jul 1, 2014 04:40 PM
