XJ ( X351 ) 2009 - 2019
Help needed how to set center analogue clock.
Old Aug 21, 2018 | 11:30 PM
Gary Watts's Avatar
Default Help needed how to set center analogue clock.
Hi all I just brought my xj portfolio 2010 this is my first post everything is perfect with the car so far except I can't find how to adjust the analogue clock in the center of the dash ive checked the owners manual but cant seem to find any info. Any help would be lovely.
Thanks gary
Old Aug 22, 2018 | 02:56 AM
xdave's Avatar
Thanks gary
Hi Gary,
It is adjusted along with the digital clock using the main touch screen. From the home screen press and hold on the digital clock in the top corner for a few seconds and you will be taken to the adjustment screen.
Old Aug 22, 2018 | 04:54 AM
Gary Watts's Avatar
Hi I have tried that it just sets the digital clock in the virtual instruments panel. The analogue clock in the centre of the dash is working the hands move but the time is incorrect and during me mad.
Thanks Gary
Old Aug 22, 2018 | 07:59 AM
Stuart S's Avatar
Now you know why the previous owner sold it.
Old Feb 14, 2019 | 04:01 AM
Joe Smith's Avatar
Thanks Gary
you need to disconnect the clock and reconnect it. To access the clock the vents either side need to be removed. You can do this using a glass hook or something similar by inserting it right into the vents and pulling towards you. The clock has 2 push points either side and it will then be able to lift out
Old Feb 14, 2019 | 06:01 AM
XJsss's Avatar
Have you tried going through the touch screen settings?
Old Feb 14, 2019 | 08:24 AM
clubairth1's Avatar
Community Influencer
I think he has already tried that and it did not work?
Old Feb 14, 2019 | 10:30 AM
XJsss's Avatar
I read where xdave was suggesting setting via the digital clock on the home screen and not through the settings.
Old Feb 14, 2019 | 11:21 AM
xdave's Avatar
Holding your finger down over the digital clock is just a shortcut to the same settings screen without having to go through the menus.
If the analogue clock is not responding when making changes to the digital clock, but is otherwise incrementing correctly, it sounds like a fault. You could try disconnecting the vehicle battery for a few minutes first which I think stops the clock counting, and see if that resets it. If not remove it as Joe details and replace if still faulty.
Old Feb 14, 2019 | 01:04 PM
christ's Avatar
Stick a Jaguar logo over the clock, and just use the digital readout.
vmaxie
Jan 17, 2017 01:09 PM
vmaxie
Sep 12, 2014 02:13 PM
MARVSGT
May 6, 2009 09:30 PM
