XJ ( X351 ) 2009 - 2019
Help!! Rpm fluctuations while driving
Old Aug 22, 2021 | 08:19 PM
Benjibooji's Avatar
Default Help!! Rpm fluctuations while driving
Hopefully someone can help out...
My 2010 xjl 3.0d portfolio has developed a strange fault, idle is fine and holding any rpm while there is no load there's not a single problem. Once under load the rpm fluctuate's by around 3-400rpm at any speed in any gear even while cruise control is used the car surges with each change. It's constant under load. This fault started after its MOT 2 weeks ago and I cannot find the cause. I have checked intake pipework hot and cold side all o2 sensors MAF sensors and I have had the vehicle scanned. I fitted a gearbox over a month ago which has been absolutely faultless. For MOT it received new rear upper arms both sides new brembo front disks and pads then a full set of Dunlop tyres. Any help or advice would be welcomed with open arms
Thanks,
Ben
Old Aug 23, 2021 | 10:35 AM
Vasara's Avatar
Hmm.. If you don´t have any codes, all sensors are working, but some propably are giving wrong info. I would try to swap places of the MAF sensors together. Upper one are used only for 2nd turbo, over 3000rpm (or somethig), therefore it is much less used. They are identical parts, so you can swap them freely.
Second easy check comes in my mind are the MAP sensor, right at top of the engine, on Y - intage.(throtle body)
I would say that the EGR are stuck partly open for the symthons, but you should have bright light on dash and codes on scanner... Exept, if your vehicle are "softed them out"?
Then more difficult task: You wrote that it started after MOT. Does MOT include the smoke test with full throtle? (in my country it does) There are change for timing belt (or high pressure pump belt) to jump on tooths in sudden "free full throtle" runup to max. If i understand right: one tooth on timing do not cause mechanical harm, but more than one can cause valves to kiss pistons. (not as romantic as it headrs)
You might also have stuck or faulty injector. It might work Ok on low volume, but when more capasity are needed it might just be sqiurting fuel, instead of spraying. An professional shop are needed to test them.
countyjag
Dec 11, 2021 06:33 AM
EsRay
16
May 26, 2021 04:13 AM
Vee
Feb 6, 2015 11:37 AM
Tahoe Dave
Mar 16, 2012 12:44 PM
Mafioso
Feb 27, 2011 10:01 AM
