XJ ( X351 ) 2009 - 2019
Illuminated moldings
Old Oct 16, 2018 | 06:15 AM
lolshto's Avatar
Default Illuminated moldings
Hi.
I would like to replace my door moldings with Jaguar label on them, since they are a bit worn out.
I have an illumination package and I wonder if illuminated and non-illuminated are still the same?
I want to buy one set, but I can't figure out whether they will suit me or not.
Old Oct 16, 2018 | 06:27 AM
christ's Avatar
Assuming that you mean the tread plates, it is my understanding that they are a like-for-like replacement, as the connections for illumination are simply tucked away beneath the non-illuminated tread plates (the same is true for the boot/ trunk access plate). The only potential poo-trap is the wheelbase - obviously the rears are different for the SWB and the LWB!
If you mean something else, sorry - I can't help!
Old Oct 16, 2018 | 09:15 AM
xdave's Avatar
Likewise assuming tread plates - if the wear is superficial scratching only you can take them into your local metal working shop and get them refinished for a lot less than even used prices. You could refinish down about .5mm to remove occasional deep scratches.
The treadplates are the same size between illuminated and non-illuminated (LWB rears are different to SWB rears), but the illuminated ones have a cutouts with an acrylic insert that acts as the light pipe/guide which the normal ones don't have.
Old Oct 16, 2018 | 03:42 PM
Stuart S's Avatar
For illuminated tread plate installation details, see:
https://www.jaguarforums.com/forum/x...plates-153556/
Tommy Ferrugia
Oct 5, 2016 07:43 AM
Danomar200
Jan 30, 2015 09:08 AM
oldpunk
Apr 28, 2013 08:28 AM
portman5
XJ40 ( XJ81 )
Nov 28, 2012 09:09 AM
dmarti02
Dec 7, 2008 12:30 PM
