XJ ( X351 ) 2009 - 2019
Jaguar XJL - Supercharged - Repair project
Old Aug 11, 2023 | 10:48 AM
Whipas's Avatar
Default Jaguar XJL - Supercharged - Repair project
Hi Everyone,
I bought a wrecked 2013 Jaguar XJL - 5.0L Supercharged and am getting it repaired. Finally, we were able to make the engine run (the fuel system was filled with gunk and the engine didn't run) and I am seeing that the supercharger is making a louder noise than I am assuming it should?
The car came with all the main engine parts on, including the SC and all the belts and so on, so we didn't touch anything, but the sound seems a bit excessive. Is the noise ok? The noise is only coming when giving it throttle.
https://www.youtube.com/shorts/495Npb7YADQ
Old Nov 30, 2023 | 08:25 PM
Lightspeed's Avatar
That is 100% NOT normal, and is not supercharger whine.
you posted that some time ago how did you go with your findings with your project?
Old Nov 30, 2023 | 10:26 PM
lotusespritse's Avatar
If you take the belt off the supercharger and turn it by hand, how does it feel and sound? It should be butter smooth and quiet.
Old Nov 30, 2023 | 11:46 PM
Lightspeed's Avatar
Dead right, if the charger is still making noise by hand rotation, its not common but the blades on the compressors may be interfering with each other, not common but I have seen it, that would possibly indicate the charger has been disassembled and incorrectly aligned at re assembly, not likely but possible.
Use a mechanics steth and touch the snout to try to ascertain the source.
Old Dec 3, 2023 | 09:41 PM
dennis black's Avatar
20 Year Member
Supercharger Coupler
Jaguardeseo
Feb 28, 2023 10:21 AM
BADVPR
Nov 18, 2021 01:38 PM
1Q2w3e4r5t
Jun 26, 2020 08:44 PM
kmarajh
Aug 20, 2016 09:57 PM
Scott Bourne
Photography
Aug 15, 2013 12:39 AM
