XJ ( X351 ) 2009 - 2019
LED Mirror Puddle Lamps
Old Jan 7, 2025 | 07:23 AM
clubairth1's Avatar
Community Influencer
Default LED Mirror Puddle Lamps
I have seen people swap the bulbs out for LED's in the mirror puddle lights but I like this style much better and it throws much more light as well.
These are common and all over plus fit other car brands too like Volvo. About $15 a pair.
Mirror Puddle Lights
Now I found a great thread on installing these little guys and it took a bit of fiddling to release the tab on the stock light but in the end it was simple and quick after you mess with it a bit!
Here is the thread;
Remove Puddle Lamp Instructions
Attached is a bit from the workshop manual as a picture is worth a thousand words. There is a small access window at the bottom of the mirror if you tilt the glass up and back so you can see it. Read the directions in the above thread and I purchase and used the great little tool called a chip lifter to release the tab and get the stock lights out.
It's a Wiha 26810 - Chip Lifter. A little screw driver looking tool with the perfect curved end to get in and release the light tab.
It's under $10 and can be found everywhere on EBay and Amazon.
So the entire project was right at $25 cheap when your in the Jaguar world for sure!!
File Type: pdf
Old Jan 7, 2025 | 09:22 AM
ABrice's Avatar
I purchased a set of those about a year ago. They are a thousand times better than the OEM puddle lights!
Old Jan 7, 2025 | 03:58 PM
EliteZags's Avatar
anyone find these in blue anywhere
Ilovegoold
Dec 17, 2019 01:06 PM
lcmjaguar
Jul 13, 2014 01:12 AM
Pristine97XK8Convertible
Jun 7, 2013 12:28 PM
hlgeorge
Dec 24, 2012 02:55 PM
Ck2118
Aug 11, 2012 09:48 PM
