XJ ( X351 ) 2009 - 2019
Losing coolant
Old Dec 12, 2017 | 09:31 AM
Dennis Jolicoeur's Avatar
Default Losing coolant
I am losing coolant in my 2013 XJL 5 liter supercharged. There are no visible leaks, it is not losing a lot of coolant but I am topping it off every few weeks. Took it to my mechanic and he run pressure tests and believes it is a head gasket. Has anyone run into this problem? How big of a job to repair?
Old Dec 12, 2017 | 11:22 AM
rhomanski's Avatar
A head gasket is a fairly large job. The supercharger and everything around the head has to come off. If that is the problem make them replace all the plastic tubes in that area as well. A bad head gasket will look like a slight loss of pressure, about 2 PSI, and then will hold steady from then on. Your filling the cylinder with antifreeze and when it fills up no more pressure will be lost. A slow steady drop that doesn't stop is a leak somewhere and keep looking for a puddle. If it doesn't drop and doesn't leak anywhere replace the radiator cap. I've had head gaskets done before for about $1,200 on a Pontiac v6. At least double that for a supercharged Jaguar I would suspect. That is if they take it to a machine shop and have the head shaved to be flat again. Aluminum warps and that's why you get a leak. Getting on it a lot will stress the aluminum and over time will blow a gasket. Depending on the mileage you might want to have them look at the timing chain guides as well.
Old Dec 12, 2017 | 11:43 AM
NBCat's Avatar
Did your mechanic inspect the water pump?
Old Dec 12, 2017 | 03:52 PM
clubairth1's Avatar
Community Influencer
An other vote for the water pump. The 5.0L rarely loses a head gasket.
Maybe test the coolant for combustion gases first?
Old Dec 13, 2017 | 12:18 AM
dga57's Avatar
I had a head gasket failure at approximately 47,000 miles on my 5.0L SC which, fortunately, was covered under the new car warranty. It was at the dealership for about a month and they did send the head out to be milled. Has been fine since the repair.
Dwayne
Old Jan 20, 2018 | 12:23 AM
Polyesterpig's Avatar
Put the car on a lift and remove the aero pans. Look at the top of your transmission bell housing. If you see green coolant drippings, you need to replace your rear crossover tube. A pain, but better than replacing head gaskets.
Old Jan 20, 2018 | 01:10 PM
Stuart S's Avatar
Where's the OP? Why no updates in over a month?
bluerdg
Aug 15, 2011 11:15 AM
MLRocafella85
May 5, 2011 03:58 AM
wayne1991
Apr 12, 2010 09:15 PM
Ricky3r
XJ40 ( XJ81 )
Mar 30, 2010 09:39 PM
Dec 17, 2007 01:14 PM
