XJ ( X351 ) 2009 - 2019
Media Controller - Battery? Does not Work
Old Feb 14, 2022 | 08:06 AM
jschimmels's Avatar
Default Media Controller - Battery? Does not Work
I had this back-seat media controller replaced when I bought the car about 6 years ago. It has never been used since and I can't get it to turn on. I opened the back and there is no battery that can be replaced. Do any of you know if there is an internal battery that needs to be replaced? If so, how does it open. Please let me know if you have any ideas.
Old Feb 14, 2022 | 10:12 AM
Vasara's Avatar
Hi, not sure if thre are user changeable battery inside, but i am pretty sure it have some sort of battery inside, bacause it works wirelesly. (seen one in action on exhibition)
The unit should wake up when it is on its socket in rear midle armrest. It will get power/charge from golden fingers visible on backside. If it dosen´t, measure if you have voltage on the armrest? (Blown fuse?)
Note: If the control device have, been without power for 6 years, the internal battery cell are most likely dead by undervoltage. It might be soldered battery and most cases standart flat cell type available from electronics shops.
Hmm... I re-read your post and noted that your control device was replaced. Was it brand new controller? Did you saw any lose cables inside when you opened it? -> Most cases inbuild batterys are protected for self-life by remowing the battery wire from its connector. Maybe its just that the battery wire are not connected when they replaced your controller?
Old Feb 15, 2022 | 09:23 AM
jschimmels's Avatar
It was a brand new replacement. Everything worked perfectly when I tested it after they fixed it. I hadn't used it since. You are right in that it has to have some kind of battery inside. Any idea on how to open it. It did not turn on while set in its cradle indicating a larger issue.
Old Feb 15, 2022 | 09:33 AM
XJsss's Avatar
Has the charger circuit been checked to see if it is getting power?
Old Feb 15, 2022 | 10:21 AM
Vasara's Avatar
Hi,
Ok.
I spot from youtube XJ demonstration video that the Home button (picture of House) are an Power On button. Try that.
As XJss write too, the armrest charger point are worth to measure for power feed.
twoblackjags
Mar 19, 2024 06:41 AM
datriani
Feb 21, 2024 12:58 PM
mhamilton
29
Jan 19, 2023 07:24 AM
ericisback
E type ( XK-E )
Nov 16, 2021 07:46 AM
kench
Nov 23, 2011 08:40 AM
