XJ ( X351 ) 2009 - 2019
My 2013 XJ Supersport Arrived
Old Oct 26, 2012 | 03:50 AM
GilesGuthrie's Avatar
Originally Posted by barryf43
Beautiful car! Do your side vents say Supersport? It doesn't look like it from the pictures but its hard to tell. I had an interesting Jaguar screw up with my car. One side vent says Supercharged like it's supposed to, but the other side vent says Supersport. My dealer said they would fix it under warranty, but I left them that way to remind me that Jaguars can still be quirky British cars.
The supercharged one is known as the Supersport in Britain (perhaps elsewhere also). Mine says Supersport on both vents.
Old Nov 12, 2012 | 05:39 PM
XJsss's Avatar
Only 3 weeks I now have over 1300 miles on the car and have had it to the dealer to change the side vents to the proper ones that say SuperSport from the no name ones inadvertently installed at the factory, and that was no easy task as they have 4 bolts holding each of them on and necessitated the r& r of the inner fender covers around the wheels and the r & r of the windshield washer tank on the right side. Also had the instrument cluster display changed as there was a stuck on red pixel. Lastly had the exhaust tips aligned as they were not “perfect”. In my driving I have adjusted the tire pressures to 35psi for best ride/handling and the cat just is now stuck to the road and the ride is firm but not bounty or jittery. I have an inquirery into changing the keys to the later release that is smaller and lighter and will report back on that.
Old Nov 12, 2012 | 05:58 PM
JgaXkr's Avatar
Contact your dealer in a week or two as Jaguar will be releasing a service bulletin for cars below vin V41896. this will address the keys on early cars. When you call mention K140. They will know what it means.
Old Nov 13, 2012 | 07:17 AM
The_Ikon's Avatar
Beautiful car! Oh how I hate you right now.
Enjoy your car... I still hate you...........
Old Nov 15, 2012 | 02:33 PM
woodyp's Avatar
Default question about the XJ Supersport
What is the brown thing on the ceiling? Is it a sunglass holder? I first noticed this on the XJL Supersports. On those LWB models..."whatever that option was" was nestled between the two rear vanity mirrors. Just curious.
Originally Posted by XJsss
Now that I have had the Cat 2 days and have a grand total of 118 miles, here are my initial impressions. I am taking it easy so far and only use 1/3rd of the accelerator pedal movement and it is scary fast already. I have had it up to 90 and cruised at 80mph (no steady running yet during my break-in period) and the tack reads 1700RPM. So the 8 speed is set very tall on 7th and 8th gears. This transmission is so sweet glad I waited. I am still up in the air about the stop/start feature, but have found that when at a stop is I have lighter pressure on the brake pedal and the car is not moving the engine stays lit and with firm pressure the engine does the stop/start. The stop/start initially was a little rough but is smoothing as the Cat and I become more acquainted with each other. The Meridian audio is fantastic and the only car audio that I have heard that might be a tad better are custom builds. When set on the Meridian configuration each passenger has said that the surround effect made them feel in the middle of the listening area. Next the suspension, initially there was a lot of “jiggle” and as the tires have worn in that has reduced but is still there a bit. Since I have the Speed package and therefore a top end of 174mph the technician set the tires at 39psi, so I plan to play with the tire pressure since I can run it as low as 32psi, so I’m of going to try 35psi to start from and see how it feels and play around to find what works best. Stay tuned and I’ll be updating again. Here are some photos, and as for the question about the headliner only the center sections all the way back are perforated and as this is a SuperSport the headliner is all leather. Stay tuned
Old Nov 15, 2012 | 04:09 PM
roviw's Avatar
I believe the unit on the ceiling is to do with the wireless linking of headphones to the AV system.
Old Nov 15, 2012 | 07:50 PM
barryf43's Avatar
Does this bulletin apply to 2012 models too?
Old Dec 5, 2012 | 11:40 AM
  #28
tommyd's Avatar
Anyone have an update regarding service bulletin K140?
Old Dec 13, 2012 | 09:09 AM
XJsss's Avatar
Went to dealer this AM and got the new "keys" under the K140 Program, they are definitely smaller and lighter, but not as distinctive. Here are a couple of photos.
Attached Thumbnails My 2013 XJ Supersport Arrived-jaguar-keys.jpg   My 2013 XJ Supersport Arrived-jaguar-keys-2.jpg
Old Dec 13, 2012 | 10:32 AM
  #30
carzaddict's Avatar
they didnt charge you anything?
Im going to try that
Old Dec 13, 2012 | 12:20 PM
  #31
Executive's Avatar
Very nice! I really like the new remote.
Old Dec 13, 2012 | 12:39 PM
  #32
tommyd's Avatar
Do you have to switch over both or can you have 1 older style and 1 newer style?
Old Dec 13, 2012 | 06:08 PM
  #33
JgaXkr's Avatar
The update ONLY applies to early 2013 cars that came thru with the early remotes.
Old Dec 13, 2012 | 09:06 PM
  #34
BlackX300VDP's Avatar
Those are the same keys for the '12 and newer Rovers as well (just with a LR logo in place of the Jaguar logo)
Old Feb 24, 2013 | 09:45 PM
  #35
Deecutts360's Avatar
SWEET ride!!
Old Apr 1, 2013 | 08:53 PM
  #36
nguyennhatquang's Avatar
the new key look exactly like the Range rover one..
and it look very cheap. i like the old one better.
i saw the New style one the chrome wear out of it look very terrible in the Range rover...
Old Apr 2, 2013 | 04:06 PM
  #37
XJSC's Avatar
Yes quirky for $100k cars! I've had my supercharged for just over a week and noticed that the illuminated trunk sill was not installed, even though I got the Illumination Package as an option. The part is on order, and I need to bring it in to be installed. Makes me want to walk around and inspect the car! Amazing they would let these quality control issues go through. Either the workers are not paying attention on the assembly or the work flow planning is poor.
WhiteJag
Oct 1, 2015 01:57 AM
10 XF Premium
Oct 1, 2015 12:47 AM
sdelliott58
Sep 28, 2015 11:21 PM
d33
Sep 26, 2015 11:02 AM
