XJ ( X351 ) 2009 - 2019
Navigation on instrument panel
Old Jun 15, 2014 | 08:11 PM
Carpe Diem's Avatar
Default Navigation on instrument panel
When using in-car nav, the left hand instrument gauge is no longer changing to upcoming instruction (ie left turn). I have searched manual, web and this forum, but no luck.
Is there a setting that turns this function on/off?
Thanks in advance!
Sean
Old Jun 16, 2014 | 05:40 PM
roviw's Avatar
Copy and paste from the online handbook that I have stored on my PC
TURN-BY-TURN NAVIGATION
Turn-by-turn navigation guidance (displayed in
the message centre) can be turned on or off as
follows:
From the main navigation menu, select Nav
Setup, then select User Settings.
Scroll through the user settings list until the
Message centre guidance band is displayed.
Touch the band to select/deselect the feature.
The band is highlighted when message centre
guidance is enabled.
Old Jun 17, 2014 | 02:08 PM
Carpe Diem's Avatar
Perfect, thank you!
Do not remember de-selecting that option, but I must have. It seemed to happen right after i set up my bluetooth. Bluetooth status shows in same window, so thought maybe nav and bluetooth could not be on simultaneously.
I have a soft copy of the 'XJ Owners Handbook (Publication Part No. JJM 10 02 34 121), which does not seem to have same level of detail as yours.
Thanks again!
Old Jun 17, 2014 | 05:00 PM
roviw's Avatar
Glad to help, I cant remember where I found it online, I actually downloaded it before my car was delivered, if I find the link then I will post it for you,
Old Jun 17, 2014 | 05:03 PM
roviw's Avatar
just found the link
Jaguar International - Owners' Handbooks
n8ertot
Oct 11, 2015 02:28 PM
convincor
Oct 1, 2015 05:19 PM
Long Islander
Sep 27, 2015 03:45 PM
HuncaMunca
Sep 27, 2015 02:47 PM
