XJ ( X351 ) 2009 - 2019
Need help finding out if parts list is correct
Old Oct 26, 2021 | 09:46 AM
JordanXJL's Avatar
Default Need help finding out if parts list is correct
Hi all, I'm two months and 7,000 miles into ownership with my 12' XJL..it has been a blast! I tended to my immediate problems as some of you may remember me having on my previous and first ever post here on the forum. Now onto my preventative maintenance as I have time to actually get some more work tended to on the car again. I called my local dealership and asked for an parts list on ALL of the old plastic pieces that wear over time with the most updated replacements, water pump, and of course the coolant crossover pipes were a part of this. I wanted to ask you guys if I have all the correct parts, and if not, what to not get/what to get.
Parts: AJ89664
C2Z28647 (X2)
C2Z22073
C2Z18658
AJ813909
AJ811713
AJ811714 (X2)
Recently saw a post from someone about the plastic vacuum tubes being a serious threat to our safety as well..should I go ahead and add that to my list of parts as well?
As always, I appreciate anyone who takes the time to help me out. Safe driving!
Old Oct 27, 2021 | 09:20 AM
clubairth1's Avatar
Community Influencer
I would recommend doing searches on this forum. The dealer won't have the knowledge like this forum does. Look for a repair thread from a former member called Bigg Will on the earlier XF/XFR forum. Also The Rock88 from the F-Type forum has posted really good repair instructions.
Big question is can you DIY anything? If not pull out your wallet for any and all repairs!
Focus on the plastic cooling parts and water pump first. Those are known failure points and your car is old enough that all the cooling plastic has decayed by now. You do have the latest WP listed with the 3909 part number so I know that is correct. We have just recently found a metal replacement for a plastic cooling part and I have been recommending it. I have it but it's not installed yet. Pretty cheap too.
Metal Cooling Pipe
If you want help on those part numbers I would add a short description of what they are. Does it include the rear water manifold?
Old Oct 27, 2021 | 02:44 PM
JordanXJL's Avatar
Heck ya, will do. As always, thanks airth!
davidladewig
Nov 10, 2016 12:39 PM
reichstall
Dec 20, 2015 06:41 PM
JBann
Mark V - X 420G
Dec 25, 2014 01:49 PM
Mark SF
Nov 7, 2014 12:57 PM
