XJ ( X351 ) 2009 - 2019
Need Help My 2012 jaguar xj , is have a crank no start & no codes
Old Feb 22, 2025 | 05:58 PM
JohnDominguez's Avatar
Default Need Help My 2012 jaguar xj , is have a crank no start & no codes
Replaced Fuel rail sensor ,Lp fuel pump and injectors while doing valve cover seals
, all i know is the car is sending fuel to the engine but doesn’t wanna start i even replaced the battery
Old Feb 23, 2025 | 01:52 AM
Vasara's Avatar
Did it run before you start? If yes, then go backwards your work.
Do you have any diag tool for checking crank sensor pulse when you try to start?
Old Feb 24, 2025 | 05:27 AM
Jaaag_drivah's Avatar
What are your fuel pressure readings in SDD? Did you run "Fuel Prime Routine" in SDD to send fuel up to the HPFPs and fill the fuel rails?
bhudzallmighty
Sep 26, 2024 12:06 PM
Brian M Williams
Jul 11, 2024 07:16 AM
Jmains123
XJ40 ( XJ81 )
23
May 7, 2023 08:43 AM
geberhardt
Feb 20, 2019 08:46 AM
blkgato
Jun 15, 2011 12:41 PM
