XJ ( X351 ) 2009 - 2019
Need to recharge A/C on 2011 XJL
Old Jul 20, 2017 | 09:37 AM
BlueX's Avatar
Default Need to recharge A/C on 2011 XJL
I've watch several YouTube videos in regard to recharging A/C. Non of the videos are show the low port for a XJL. I've also tried to do a search in this forum and did not pull up a post. Can someone direct me where the port is located?
Thanks in advance.
Old Jul 20, 2017 | 01:48 PM
phillyS1's Avatar
I'll look later on when I get home if you don't find it by then, usually you can just locate and follow the lines to find the port. Also, The can will only fit the correct line.
