XJ ( X351 ) 2009 - 2019
New coolant routing out of the water pump
Old Jan 27, 2017 | 02:26 PM
hafren's Avatar
Default New coolant routing out of the water pump
Does anyone have the TSB that explains how these new hoses connect into the existing system. I know C2Z28467 connects to the thermostat but want to verify where AJ813565 connects into the system for 5.0 non-supercharged
From post #67 of https://www.jaguarforums.com/forum/x...r-pump-120768/
Originally Posted by Mccainszoo
The fix for the water pump may be the new way the coolant is routed out of the water pump. I believe it allows for better flow and less back pressure. The two part numbers for the new hoses are AJ813565 and C2Z28467.
Old Jan 27, 2017 | 07:51 PM
hafren's Avatar
I have found this, a not very clear description of the change, but hope someone can post the relevant TSB or clearer directions.
File Type: pdf
