XJ ( X351 ) 2009 - 2019
No air from any vents except the window.
Old Mar 2, 2023 | 11:20 AM
vika01's Avatar
Default [SOLVED] No air from any vents except the window.
SOLVED.
As the title says. Since yesterday no air comes from any of the vents except the window defrost vents. And also got the ”Restricted performance” red warning and the e-brake didn’t work for a short moment today. Now it’s just the vents.
Anyone who knows what causes this to happen so no air comes from the vents? Is it the blend door actuator?
2012 XJ.
Old Mar 2, 2023 | 11:26 PM
ralphwg's Avatar
Check your battery. If it reads below 12.6V at the battery terminals with everything shut down. You have a battery problem. If you need to get a new battery make sure it is fully charged before it is installed. Our cars tend to have a picky electrical system that doesn't like weak batteries.
Old Mar 3, 2023 | 02:12 AM
vika01's Avatar
Thank you. I recharged the battery, checked the air filter. Then thought that I should simply check the climate settings in the menu. Turned out that this was the issue. I needed to reselect the air flow to the dashboard and rear vents. It’s now resolved.
cse
Jul 20, 2022 05:04 PM
shikole
Aug 18, 2017 06:29 AM
nikmott
May 7, 2014 05:18 PM
yabadabado57
Mar 13, 2012 05:18 AM
