XJ ( X351 ) 2009 - 2019
No start
Old Feb 15, 2024 | 03:37 AM
Rick Right's Avatar
Default No start
2012 jag xj 5.0l not supercharged
Buddy changed his coil packs and spark plugs on the pass side , now no start I changed the harness for cam adjustment as they were broken and chaffed solderd them in , still no start , no 5 volt to both sides of cam sensors , no 5 volt to crank sensor , I have tested that no wires are broken on every wire , I tested every ecm fuse , I swapped all the relays under the hood , what else should I test , also car ran fine before changing coil packs and spark plugs on pass side and swapped back in the old coils and spark plugs
iownme
Jul 4, 2018 06:22 AM
Bones
Sep 8, 2015 08:34 PM
seagates5
Apr 9, 2015 05:23 PM
johnr
Oct 1, 2014 09:50 AM
crookjag
Jul 12, 2011 07:10 AM
