XJ ( X351 ) 2009 - 2019
Passenger side mirror dip in reverse 2011 XJL
Old Dec 22, 2018 | 04:07 PM
Donm's Avatar
Default Passenger side mirror dip in reverse 2011 XJL
Replaced pass side rear view mirror and now it turns in but not Down. Where can I modify this in settings?
regard,
donm
Old Dec 22, 2018 | 04:59 PM
JaguarJeffrey's Avatar
From the owner's manual. The mirrors can be configured so that when reverse gear is selected, the passenger door mirror is automatically adjusted to provide an improved viewing angle for reversing.
The exact dipped position can be adjusted using the joystick control, when the mirror is dipped. The next time reverse is selected, the newly adjusted position will be selected.
When the gear selector is moved out of reverse, or if vehicle speed exceeds 7.5 mph (12 km/h) while reversing, the mirror will return to its previous position.
Mirror dip can be selected or deselected from the instrument control panel. Press the OK button on the joystick control on the right side of the steering wheel. Use the "down" arrow and select Vehicle Settings, then Features. The mirror control option is in that sub-menu.
Greggbhill
Aug 26, 2018 11:09 PM
Pristine97XK8Convertible
Aug 25, 2017 04:15 PM
DavidT
Apr 19, 2014 09:28 PM
Holeecow
Sep 2, 2013 10:00 AM
harryc
Feb 28, 2012 01:52 PM
