XJ ( X351 ) 2009 - 2019
Performance upgrades?
Old Aug 11, 2020 | 05:29 PM
Luis Perez's Avatar
Default Performance upgrades?
Hello, so I have a 2012 XJ and I have been looking for a good programmer or tune for some minor performance upgrades but mostly to remove the speed governor but can’t seem to find any. Does anyone have some advice or know of any good products?
Old Aug 11, 2020 | 08:21 PM
tjankovs's Avatar
You can remove (set to 217mph) the speed limiter with SDD. The software is free online but you need to buy a cable, get a power supply, and have a laptop with Win 7-32.
Old Aug 11, 2020 | 10:51 PM
Luis Perez's Avatar
That sounds really useful but is there any alternative?
Old Aug 13, 2020 | 07:59 AM
carzaddict's Avatar
is the software free? i thought it wasnt. what kind of cable do i need? OBD to ethernet? are there instructions on how to install and run?
Old Aug 13, 2020 | 08:57 AM
Stuart S's Avatar
A normally-aspirated engine will never have the low-end torque provided by a supercharger.
Save your money and put it towards buying a 2013-up XJ with the 5.0L SC engine, 8-speed transmission, and Meridian Surround Sound system. You'll be glad you did.
Removing the speed limiter without upgrading your tires to the comparable speed rating is a recipe for disaster. Be safe, not sorry. Tires are not the only improvements that may be needed.
Old Aug 13, 2020 | 11:00 AM
clubairth1's Avatar
Community Influencer
No XJ ever had a speed limiter set to 217 mph. Mine is now at 200 mph from the VAP stage II tune. Stock my XJR was limited to 174 mph. ALL other XJ's are much less and a lot of them were set at 121 mph from the factory because of tire limitations. Note mine can and has exceeded the stock 174 mph number so the car has the ability IF you have enough road!
I also have SDD and no one has used this to adjust the speed limiter?
Can you point out where it is in SDD? I have used it a good bit but as always there is a bunch I don't know!
Old Aug 14, 2020 | 06:58 AM
tjankovs's Avatar
You need to edit the car config file in SDD. There are a few options to set it to from the drop down. I moved mine from 194kph(121mph) to 350kph(217mph). I think it could only reach that falling off a cliff. There are lots of other nice modifications you can make. i enabled global open and close from the remote and dash button, turned off the DRL, and removed the 30s auto relock. There are a lot of parameters without any real description so you need to be careful, keep good notes, and just change one parameter at a time..
woodardjl
Feb 15, 2025 03:58 PM
RussellxjLSC
Mar 11, 2020 06:50 PM
pumba
Mar 25, 2014 01:50 PM
LadyPenelope
Oct 6, 2009 11:16 PM
