XJ ( X351 ) 2009 - 2019
Plastic Push Pin Part Number?
Old Sep 22, 2019 | 02:44 PM
clubairth1's Avatar
Community Influencer
Default Plastic Push Pin Part Number?
I am missing some plastic push pins that hold an air duct onto the frame on my 2014 XJR.
This is where they go;
This is only visible when the under body shields behind the front bumper are removed.
Here is a picture from the drivers side of the car. The duct is hanging down.
The push pin looks like all the others but is bigger in diameter.
Can't find them in the JEPC. Anybody have a part number?
Old Sep 22, 2019 | 06:56 PM
dmchao's Avatar
I’ve been looking for this as well. I’m planning to buy a variety pack of plastic spread rivets to see if I can find a suitable replacement. Usually these are designed to last less than 10 push pull cycles anyway.
Old Sep 22, 2019 | 08:51 PM
Stuart S's Avatar
It'll probably save you some time by buying an inexpensive assortment of Ford push pins on Ebay. I suspect that because Jaguar used to be owned by Ford, that the Ford push pins will work. It's just finding the right size, which shouldn't be a problem with an assortment.
Old Sep 23, 2019 | 07:51 AM
clubairth1's Avatar
Yes I thought that too but so far I have not found what I need in those random assortment packs.
Really thought it would be in the JEPC but there are a number of different ones of those too.
Old Sep 23, 2019 | 08:21 AM
dmchao's Avatar
This one was similar, but I'm still sticking to my plan of getting an assortment from auto zone.
XR88883
https://www.ebay.com/itm/New-OEM-Jag...d675%7Ciid%3A1
Old Sep 23, 2019 | 09:19 AM
hafren's Avatar
It is most likely a Ford part so you could measure what you have then search here for it https://www.clipsandfasteners.com/Fo...h-p/a18894.htm
ceejay
Aug 8, 2017 12:46 PM
Rickkk
Mar 21, 2017 12:02 PM
Julian Black
Dec 4, 2016 03:49 PM
Humy
Mar 29, 2012 09:22 AM
Mexk8
Mar 16, 2012 05:11 PM
