XJ ( X351 ) 2009 - 2019
Problème multimédia jaguar xj 351 2011
Old Nov 3, 2022 | 11:56 AM
sulli62's Avatar
Default Problème multimédia jaguar xj 351 2011
Bonjour peut être pourriez vous m’aider voilà j’ai une Jaguar xj 351 de 2011 alors tout la parti multimédia ne fonctionne plus , la radio s’allume 10seconde au démarrage du véhicule au matin et terminer plus rien ne fonctionne pas de radio , gps ni camera je chercher désespérément la panne
merci d’avance de votre aide
Old Nov 3, 2022 | 12:31 PM
NBCat's Avatar
Bienvenue sur le forum ! Où êtes-vous situé ?
Ici, on parle anglais, veuillez écrire votre question en anglais pour que quelqu'un réponde. Merci !
Old Nov 3, 2022 | 12:34 PM
NBCat's Avatar
Here is a link to the X351 Workshop Manual (en anglais):
https://www.dropbox.com/s/jife7kkbcl..._2014.pdf?dl=0
Fraser Mitchell's Avatar
I've translated your French into English using Google Translate
Hello maybe you could help me here I have a Jaguar xj 351 from 2011 so all the multimedia part no longer works, the radio lights up for 10 seconds when the vehicle is started in the morning and finish nothing more does not work radio, gps no camera I'm desperately looking for the breakdown
Thank you in advance for your assistance
You will get the best responses by posting in English if you can. Google Translate is not bad as an assistant. The forum is very much biased towards the USA and English is usually expected on posts. If the car is running OK it does look as if you have a problem with one of the electronics modules, (or the links to them), that support the in-car entertainment, satnav user screen.
Old Nov 3, 2022 | 04:00 PM
sulli62's Avatar
hello, yes the rest of the car everything works no worries really only the multimedia part but impossible to find I'm starting to get tired from looking
Old Nov 3, 2022 | 05:58 PM
thierry_1500's Avatar
Had this once, it was a weak battery. Reconditioning it with my Ctek did solve the issue.
Old Nov 4, 2022 | 08:53 AM
sulli62's Avatar
thank you, I have just tried but still the same I have music for 5 seconds and finish nothing more or camera, radio and gps. if the amplifier part that is in the trunk is defective, does it cut off all the multimedia, even the camera and gps? because the amplifier turns on and off at the same time or everything crashes? thank you in advance
chuckh007
Apr 16, 2014 11:18 PM
Pa.Bill
Dec 22, 2013 07:32 AM
AutoMedia
Dec 15, 2010 03:06 PM
RET
Nov 27, 2010 04:06 PM
hunterjah
Sep 14, 2010 05:24 AM
