Problème multimédia jaguar xj 351 2011
Bonjour peut être pourriez vous m’aider voilà j’ai une Jaguar xj 351 de 2011 alors tout la parti multimédia ne fonctionne plus , la radio s’allume 10seconde au démarrage du véhicule au matin et terminer plus rien ne fonctionne pas de radio , gps ni camera je chercher désespérément la panne
merci d’avance de votre aide
Here is a link to the X351 Workshop Manual (en anglais):
https://www.dropbox.com/s/jife7kkbcl..._2014.pdf?dl=0
Hello maybe you could help me here I have a Jaguar xj 351 from 2011 so all the multimedia part no longer works, the radio lights up for 10 seconds when the vehicle is started in the morning and finish nothing more does not work radio, gps no camera I'm desperately looking for the breakdown
Thank you in advance for your assistance
thank you, I have just tried but still the same I have music for 5 seconds and finish nothing more or camera, radio and gps. if the amplifier part that is in the trunk is defective, does it cut off all the multimedia, even the camera and gps? because the amplifier turns on and off at the same time or everything crashes? thank you in advance
