XJ ( X351 ) 2009 - 2019
PVC Part Load hose.
Old Mar 8, 2025 | 06:50 PM
SuperChargedXJR's Avatar
Default PVC Part Load hose.
I’m experiencing a strange issue with my car. Everything runs fine during normal driving, but if I go full throttle—say a quick pull from 35 to 100 mph—the engine starts idling very rough when I slow down, and the exhaust pops like crazy.
When I got home and checked under the hood, I immediately heard a loud vacuum leak. Turns out the PCV hose on the passenger side had popped off the assembly at the back. No big deal—I figured it had cracked like most Jaguar hoses. I ordered a new one ($90), installed it, and took the car for a test drive.
After another full-throttle run, the exact same thing happened. As long as I stay out of full throttle, everything is rock solid.
What could be causing this hose to pop off only under hard acceleration? Both new and annoyingly, the old hose clicks into place, locks securely, and resists being pulled off by hand. The male fitting is round and doesn’t seem to be damaged. I’ve searched the forums but haven’t found anyone mentioning this issue. Has anyone else dealt with this
Old Mar 9, 2025 | 09:12 AM
clubairth1's Avatar
Community Influencer
Long shot?
Do you think maybe the engine is moving too much under full throttle? Like an engine and/or transmission mount allowing too much movement?
Old Mar 9, 2025 | 09:14 AM
Long shot?
I have thought of that but the hose and the engine would shift together. Since the hose / throttle body / PCV mount are all on the engine.
Old Mar 9, 2025 | 09:50 AM
clubairth1's Avatar
Good point! I had not thought of that.
Old Mar 10, 2025 | 05:15 AM
Jaaag_drivah's Avatar
When you go full throttle the supercharger bypass valve closes and the PCV system is under boost which is blowing this hose off. Are you sure the hose is fully seating on the male end?
giandanielxk8
Mar 18, 2024 07:41 PM
Alfadude
Dec 1, 2014 08:31 AM
bigcatdaddy99
Sep 6, 2014 02:58 AM
Robert Walker
Sep 25, 2012 12:19 PM
akubeta
Jul 22, 2010 09:14 PM
