XJ ( X351 ) 2009 - 2019
Rear brake Pad EPB wind backH
Old Nov 29, 2018 | 02:08 PM
  #41
clubairth1's Avatar
Community Influencer
No problem and we were all new once!
I use the Harbor Freight kit but you should be able to get a free loaner tool at Auto Zone or O'Reilly's.
Yes you must rotate the piston to retract it.
It's $45 which is high for HF but it is a quality tool and well worth the money!
Brake Kit
I have an XJR and use CF/Kevlar pads from Porterfield. My car has very large brakes and the pad selection is not large. I changed pads at 30K miles because of the dust from the factory pads.
One last comment I did not see mentioned? For some reason the XJ does NOT automatically apply the EPB when the car is placed in Park. This seems strange as my 2003 Lincoln LS and my 2005 S Type R both did.
So unless you manually apply the EPB it is never used!
Oh please get a shop manual. The car is beyond complex as you know! The one I got is 8700 pages!
Old Dec 9, 2018 | 07:30 PM
  #42
necpuglisi's Avatar
Originally Posted by xdave
I think there may be some misunderstanding there - I am not aware that I said the park brake cable needs to be removed from the caliper. Perhaps you took "released" to mean "removed"? It doesn't, at least not here in the UK. The use of release here means the opposite of engage (i.e. releasing the tension). That is why I added the comment about "enough" to clarify that. As I am not a mind reader, it would have been far more helpful had you simply asked the question as I quoted you above in the first instance.
I also explained how to remove the cable if needed because it makes moving the caliper out of the way of the discs much, much easier so you can tie it to the suspension out of the way rather than leave it supported by the brake hoses, as well as how to recalibrate the park brake afterwards. Both are actions the OP may, and will (respectively) encounter when elbow deep in a road-used caliper that won't retract for whatever reason while trying to prevent the pad sensor cable from being pinched by the bracket or the retaining spring from coming loose.
For the avoidance of any misunderstanding, this will hopefully be very clear:
You do not need to remove the park brake cable (unless you plan to remove the calipers from the car, or want to tie them up out of the way) but you do need to release it if replacing worn pads or discs. You must not attempt to force the park brake cable back directly as it can damage winding the adjuster screw and piston back against the cable tension and the gears in the actuator which is a great way to get "Park brake fault" messages on your instrument cluster. Jaguar didn't just add that restriction for the sake of it, or to sell diagnostic software. The warnings are prominently and repeatedly given at every step, and you can read them below.
For comparison, I've also attached the instructions for leadfoot's 2009 XF which are essentially the same.
Thanks to all for insights. I don't live within 3 hours of any jaguar dealers and ask if I can manually disconnect the parking brake caliper cable from the caliper am I getting myself into trouble?
Thank You
Old Dec 10, 2018 | 07:08 AM
  #43
necpuglisi's Avatar
Originally Posted by Rav
Hello all
I have a question. Do you need a computer to tell the Electronic Parking Brakes that you want to change the rear brake pads? Or just as normal use the wind back tool after releasing the EPB?
Thank you
​​​​​​​Rav
Understand it's not necessary to remove parking brake cable to compress piston. In the absence of a dealer (less than 3 hours away) ,Not being able to secure a wind back tool. If one could get the parking brake cable off the caliper will that allow compression of the piston? If so am I getting myself into trouble for the reinstall of the parking brake cable?
Thank You
Old Dec 10, 2018 | 11:04 AM
  #44
clubairth1's Avatar
No but do you need to remove the cables?
It's easier to wind the caliper pistons back in with the caliper bolted to the car. Hard to do on the bench.
Plus you will be breaking brake lines and losing fluid-getting air in the lines. Again no problem but be SURE to bleed them enough afterwards.
One tip I use is to use a Turkey baster and suck as much fluid out of the master cylinder as you can and replace with new fluid BEFORE starting any brake work. Even if I don't plan on bleeding the MC fluid gets crappy on all my cars.
So unless your replacing the caliper I don't see any reason to remove them completely.
Old Dec 11, 2018 | 08:26 AM
  #45
leadfoot4's Avatar
FWIW, I used a Lisle Tools, tool #28600, to wind in the pistons. This is a "cube like" tool, that has pins of varying diameter and spacing, in order to accommodate different pistons. I found that while this tool's pins did not fit the Jaguar piston, a little work with a file allowed me to make one set of the pins fit.
Old Dec 11, 2018 | 08:35 AM
  #46
NBCat's Avatar
Thank You
Use the proper tools to retract the rear caliper pistons. Here is an inexpensive example that requires no fiddling with the fit:
https://www.ebay.com/itm/Set-22PCS-U...b215:rk:1:pf:0
Old Dec 11, 2018 | 10:04 AM
  #47
PJS3's Avatar
I was considering that tool from advance auto parts as well, but glad to learn from you that it does not fit exactly. Saved me some frustration.
Old Dec 11, 2018 | 10:56 AM
  #48
clubairth1's Avatar
Yes the "cube" is an old tool and just does NOT work that well. I have one and have struggled with it many times.
I made it fit by grinding on the pins.
I finally upgraded to the Harbor Freight brake kit with pins that fit the piston. So much better!
