XJ ( X351 ) 2009 - 2019
Rear Lower Arm Bushing
Old Nov 10, 2019 | 07:28 PM
blacktrek's Avatar
Default Rear Lower Arm Bushing
Hi,
Did anyone replace the rear lower arm bushing before? Can we replace the bushing only or need to change the whole arm?
Old Nov 11, 2019 | 11:10 AM
clubairth1's Avatar
Community Influencer
Can you help us with what car you have?
Year, model maybe what engine it has?
Why are you changing it?
What's wrong?
They are not a common replacement part.
Old Nov 11, 2019 | 05:32 PM
Fraser Mitchell's Avatar
I had to have two replaced on my first X350 car, and the X351 is the same suspension. It is also found on the Lincoln LS. In m y view a poor design as suspension bushes should really last a lot longer. It is early wear on fairly simple parts like this that has given Jaguar a bit of a bad name, as wear and tear is normally not warranted, and some owners had to replace these within the warranty period !
Here's a couple of UK suppliers, there are probably US ones too: -
https://www.berkshirejagcomponents.c...s-c102x2777200
https://www.ebay.co.uk/itm/FOR-JAGUA...-/153148013912
You can also buy the bushes: -
https://www.ebay.co.uk/itm/FOR-JAGUA...-/351299093148
Old Nov 11, 2019 | 06:23 PM
blacktrek's Avatar
What's wrong?
Hi,
I'm driving a X351, 2010 XJL Supersport.
There is very loud squeky noise from my rear right lower arm bushing (rear bushing). I try to source out the bush cause the local Jaguar never sell the bushes.
Old Nov 11, 2019 | 06:24 PM
blacktrek's Avatar
Thanks. This is very helpfull.
Old Nov 13, 2019 | 07:34 AM
clubairth1's Avatar
That's a good price for the entire control arm and I would go with that. You can press bushings in and out but for that price you get all 3 bushings already installed.
Then just bolt the arm on.
With one side making noise and the price of that lower control arm I would consider replacing both lower arms at the same time.
Old Nov 13, 2019 | 04:34 PM
You need to make absolutely sure it is the lower arm. Dry steel ball joints, as per the rear upper arm can squeak. The bushes on the lower arm are not steel.
Old Nov 18, 2019 | 07:47 AM
leadfoot4's Avatar
I had to have two replaced on my first X350 car, and the X351 is the same suspension. It is also found on the Lincoln LS. In my view a poor design as suspension bushes should really last a lot longer. It is early wear on fairly simple parts like this that has given Jaguar a bit of a bad name, as wear and tear is normally not warranted, and some owners had to replace these within the warranty period !
Prior to purchasing a 2009 XF, there was a 2000 Lincoln LS in our "family fleet" for 9 years. Never had any suspension "wear out" issues, despite being driven through "road salt" laden winter roads....
Old Nov 18, 2019 | 03:44 PM
clubairth1's Avatar
Glad to see another Lincoln LS guy on here!
I had a 2003 V-8 sport and no suspension troubles either. Had it about 7 years and 130K miles.
But sway bar bushings and end links front and rear were a common wear/noise point on the LS just like the Jaguar's.
It's just a common part that wears out on many cars.
Old Apr 4, 2020 | 11:54 AM
Edwardpantani's Avatar
Hi. New here. Can anyone help or advise. I have a 2010 X351 XJ6 3.0 Diesel which recently went through a thorough check at Jaguar, with a list of items to do. I have done most things but was going to replace rear lower control arms. I undid the strut lower mounting, the stabilizer bar, the bottom hub bolt and then proceeded to loosen the two bolts that attach the arm to the rear subframe. The bolts came undone easily but after removing the plastic wheel arch liner I couldn't see a way of removing the from bolt without dropping the subframe. Equally, it appears that both the front and the back bolt have a nut with an arm that stops it rotating (allowing it to be undone and tightened from just one end) and whilst the front nut is accessible, allowing it to be put back on easily, the rear one appears to be inside the subframe, but with no access except a very small hole in the top of the subframe that I can hardly get my finger in. If I remove the bolt, I cannot see any way of getting the nut lined up and on to the bolt again for reassembly with the new lower arm in place. Am I missing something or does the whole subframe need to be dropped to do this simple job?
jya
40
Jan 7, 2020 11:33 AM
Peterinio
Jun 7, 2019 09:05 PM
paulkath
Nov 5, 2017 10:27 PM
edadoune
Aug 16, 2017 03:10 PM
